Want to make sure of my PCIe connections in Qsys.
Hi Yousef.
Can you try to generate an example design from IP catalog and use that as a reference ?
I want to make sure that my PCIe connections are correct and that I'm not missing anything.
>> from what i see it shall be no problem
I want to make sure that the host will see my PCIe address as "0x0000_0000_8f80_0000". Am I doing it right?
>> it depends on your project requirements. there is no exact right or wrong on this.
>>In Qsys, you typically configure the base address in the PCIe IP core settings. The PCIe base address is a 64-bit value that the host system will use to access the FPGA's PCIe address space. You will need to set this base address to "0x0000_0000_8f80_0000" if that's the address you want the host system to see.
Wincent_Intel
