10 years ago
wait for [variable] ns - Wait statement for a variable time possible?
Hello Community,
I got a problem with my current coding task: I want to create a small microprocessor in VHDL to work with assembly language via my mif-file. One of my tasks should be a wait statement.
The problem: it should be variable in time. I want to be able to wait as long as the number in my loaded memory is.
This code I tried to implement but it didn't compile:
when execute_wait =>
                wait for memory_data_register ns;
                state <= fetch;
In this example my memory_data_register is the content which is read from my memory. It's type is unsigned.
I'd be perfect, if somebody can help me ;)
Best,
orPoG
    Wait statements are only for simulation and indeed not synthesizable. You'll have to write a timer for this purpose.
    Hello PietervanderStar,
    thanks for your hint!
    I've now solved the problem this way:
    -- wait state
        process
        begin
            wait until clk_50MHZ'event and clk_50MHZ = '1';
                if count_1KHZ /= 24999 then
                    count_1KHZ <= count_1KHZ + 1;
                else
                    count_1KHZ <= 0;
                    clk_1KHZ <= not clk_1KHZ;
                end if;
        end process;
        process (clk_1KHZ)
        begin
            if (clk_choice = '0') then
                if rising_edge(clk_1KHZ) then
                    if (count_individual_timer < timer_time) then
                        count_individual_timer     <= count_individual_timer + 1;
                        individual_timer_EN        <= '0';
                    else
                        individual_timer_EN        <= '1';
                        count_individual_timer     <= 0;
                    end if;
                end if;
            else
            end if;
        end process;
