ICace
6 years agoVSIM 3033 (MODELSIM ALTERA) ERROR FFT IP CORE
Hello, I'm trying to simulate the FFT IP Core block with ModelSim-Altera. I have generated the testbench with the IP parameter Editor and I'm getting this error when I run the RTL Simulation: Wha...
SyafieqS
6 years agoHi Ignacio,
You can refer to this link as it same issue. You can execute manually "Generate Simulator Script for IP" in Quartus, end then run the script in Modelsim.
[1] https://forums.intel.com/s/question/0D50P00003yyO6LSAU/fft-ip-core-and-modelsim (FFT IP Core and Modelsim)
[2]https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf (Generate Simulator Script for IP)
Regards.
ICace
6 years agoHello, thank you for your answer.
I have checked the post you have sent me up, but I'm working with Quartus Prime Standard and it hasn't the tool "Generate Simulator Script for IP" and also Quartus pro has no support for my FPGA, Cyclone V gx starter kit.
