11 years ago
VHDL writing in memory
I have a hardware design running on a Cyclone IV FPGA and a software part running on a Nios II cpu on the very same FPGA. Both are sharing a dual port FPGA memory. I want the hardware part to write data on the memory and the software part to read it. The reading seems to be OK but the writing is not. Here is the VHDL code I use:
library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
entity ctrl is
    port(
        data : out std_logic_vector(7 downto 0);
        wen : out std_logic := '0';
        addr : out std_logic_vector(14 downto 0):=(others=>'0');
        clk : in std_logic);
end ctrl;
architecture rtl of ctrl is
    signal step : integer := 1;
begin
    process(clk)
    begin
        if clk'event and clk='1' then
            data <= "00000001";
            if step<4 then
                step <= step+1;
            end if;
            addr <= std_logic_vector(to_unsigned(step, addr'length));
            wen <= '1';
        end if;
    end process;
end rtl;
What I'd expect is the values written at addresses 2, 3 and 4 to be 1 but I only read 1 at address 4, others are 0.
I'm sure I'm messing something up in the sequential and concurrent statements but I can't solve this.
Could someone help me?
    The difference is because a signal in VHDL takes the last value assigned to it. In your origional code, it is reset inside the the "if hold = 10 then" branch, but this is overridden with hold <= hold + 1, hence it is never reset to 0.
    --- Quote Start ---
    That works but I don't understand what is really different. Can you explain?
    --- Quote End ---
    There are two ways to set logic priority:
    explicit and default
    explicit
    if count = 10 then
        count <= 0;
    else
       count <= count + 1;
    end if;
    default (conditional)
    count <= count + 1;
    if count = 10 then
        count <= 0;
    end if;
    In vhdl process the last statement overwrites so if this last statement is conditional that is ok.
    if it is not conditional like your code then it implies unconditional update and compiler optimises off the previous assignment
    --- Quote Start ---
    Also I have to make the hold time to be at least 8 clock cycles. Is there a document telling that?
    --- Quote End ---
    What is this hold time?
    --- Quote Start ---
    --- Quote End ---
    It's the "hold" variable in the conditional test.
    --- Quote Start ---
    --- Quote End ---
    I don't get it. hold is your local variable and you ask for a document on it?
    You are already delaying hold for 10 clock cycles before incrementing step.
    if you want further factor of 8 then just make it 80 instead of 10 so you increment every 80 clocks.
    You also need to constrain the range of your integers
    OK for the range.
    My hold local variable is there for the signals to keep a value for several clock cycles. Maybe it's not the good way of doing that. Tell me how to do that, I'm not used to it...
    --- Quote Start ---
    OK for the range.
    --- Quote End ---
    you already done that. Here is my version
    library ieee;
    entity ctrl is
        port(
    end ctrl;
        signal count1 : integer range 0 to 15 := 0;
        signal count2 : integer range 0 to 7 := 0;
    begin
        process(clk)
        begin
              wen <= '0';
              if count1 /= 15 then
                  count1 <= count1 + 1;
              else
                  count1 <= 0;
                  if count2 /= 7 then
                     count2 <= count2 + 1;
                  else
                     count2 <= 0;
                     wen <= '1';
                  end if;
               end if;
            end if;
        end process;
        data <= std_logic_vector(to_unsigned(count1, data'length));
        addr <= std_logic_vector(to_unsigned(count2, addr'length));
    end rtl;
    You generate a "wen" (write enable) which is active for one period of clk (20ns ?)
    Is it enough for your RAM ?
    With your last code, you are only writing at address addr = 0 !
