--- Quote Start ---
OK for the range.
My hold local variable is there for the signals to keep a value for several clock cycles. Maybe it's not the good way of doing that. Tell me how to do that, I'm not used to it...
--- Quote End ---
you already done that. Here is my version
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ctrl is
port(
data : out std_logic_vector(7 downto 0);
wen : out std_logic := '0';
addr : out std_logic_vector(14 downto 0):=(others=>'0');
clk : in std_logic);
end ctrl;
architecture rtl of ctrl is
signal count1 : integer range 0 to 15 := 0;
signal count2 : integer range 0 to 7 := 0;
begin
process(clk)
begin
if clk'event and clk='1' then
wen <= '0';
if count1 /= 15 then
count1 <= count1 + 1;
else
count1 <= 0;
if count2 /= 7 then
count2 <= count2 + 1;
else
count2 <= 0;
wen <= '1';
end if;
end if;
end if;
end process;
data <= std_logic_vector(to_unsigned(count1, data'length));
addr <= std_logic_vector(to_unsigned(count2, addr'length));
end rtl;
