Hi,Rysc
I 'm not using any development board ,I just want to customize a development board by myself. because no development board meet my need is avaliable.
so I should choose suitable componets, such as sdram ,cfi flash ,sram etc
then connect them to the nios ii cpu which is generated by the sopc builder
and then Analysis&Synthesis , Filter ,Time analyze,simulation and make sure every componet works well on the basis of nios ii.
and then generate netlists of my customized board
then make a board using the netlists
so I need the components desigh vhdl/verilog modules ,for examples:
I using mt48lc4m32b2-7 sdram,so I get the mtmt48lc4m32b2-7 vhdl file,and change it to symbols file,and connect it to the nios ii cpu with sdram controller port to port,
other components are in the same way
this error is occured when I systhesis my customized board.
so would you give me some advices on how to customize a development board on the basis of nios ii in quartus.
or give me some valuable meterials,
tks very much!
