12 years agoThanks for the reply guys, sorry am a bit late back replying I've had a dreaded cold!
I have had a start at writing a bit of code that detects the edge of a pulse which I have simulated and seems to work. The bit i'm stuck with is adding the portion of code that starts the counter. The edge detection output is called "mon_prescale" what I would like to do is when this signal goes hi start a counter. however when I use then if.... etc in the same process as the edge detector it throws up an error???
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity mon_prescale is
port (
clk: in std_logic;
monitor: in std_logic;
mon_prescale: out std_logic
end mon_prescale;
architecture Behavioral of mon_prescale is
signal mon_delay: std_logic;
begin
CounterProcess: process(clk)
begin
mon_prescale <= monitor and not mon_delay;
if rising_edge(clk) then
mon_delay <= monitor;
end if;
end process;
end Behavioral;
