14 years ago
VHDL State Machine: Bad State Transitions
Hi, I'm really hoping someone can help me as I'm at my wits end. I am running into a scenario where my state machine is transitioning into an invalid state. As far as I can tell, all of my paths between states are covered, but I must be doing something wrong. The states are setup to use one-hot encoding, btw.
Here's the some VHDL that reproduces the problem. It basically reads data from a FIFO and tries to write it to USB. After running for some period of time (which varies), the "packet_state" value becomes 0x00 (an invalid state value).
I've also attached a SignalTap screenshot showing the transition. I just can't understand why it happens.
Any ideas or suggestions?
Thanks!
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity USB_IO is
 port
  -- General --
  main_clk:    in  std_logic;        -- Primary clock: 50 Mhz
  -- Reset --
  reset_n:     in  std_logic := '0';
  -- USB TX FIFO --
  fifo_usb_tx_bus:  in  std_logic_vector(23 downto 0);
  fifo_usb_tx_empty: in  std_logic := '0';
  fifo_usb_tx_rd:  out std_logic := '0';
  fifo_usb_tx_clr:  out std_logic := '0';
  -- FTDI FT2232 USB I/O --
  ftdi_usb_txe_n:  in  std_logic := '0';
  ftdi_usb_rxf_n:  in  std_logic := '1';
  ftdi_usb_bus:   inout std_logic_vector(7 downto 0);
  ftdi_usb_wr_n:   buffer std_logic := '1';
  ftdi_usb_rd_n:   buffer std_logic := '1'
end USB_IO;
architecture rtl of USB_IO is
-- Create separate in and out signals for  the bidir port 'ftdi_usb_bus'.
signal ftdi_usb_bus_in  : std_logic_vector(7 downto 0) := "00000000";
signal ftdi_usb_bus_out : std_logic_vector(7 downto 0) := "00000000";
attribute syn_encoding : string;
type usb_io_state_type is (usb_io_idle, usb_io_tx, usb_io_rx);
attribute syn_encoding of usb_io_state_type : type is "onehot";
signal usb_io_state : usb_io_state_type := usb_io_idle;
type packet_state_type is (
 S1,
 S2,
 S3,
 S4,
 S5,
 S6,
 S7,
 S8
attribute syn_encoding of packet_state_type : type is "onehot";
signal packet_state : packet_state_type := S1;
begin
-- Infer tri-state buffers for our bidirectional pins.
ftdi_usb_bus <= ftdi_usb_bus_out when ftdi_usb_rd_n = '1' else "ZZZZZZZZ";
ftdi_usb_bus_in <= ftdi_usb_bus;
 process(main_clk)
 begin
  if(rising_edge(main_clk)) then
   -- Default our outputs.
   fifo_usb_tx_clr <= '0';
   fifo_usb_tx_rd <= '0';
   ftdi_usb_wr_n <= '1';
   ftdi_usb_rd_n <= '1';
   if(reset_n = '0') then
    usb_io_state <= usb_io_idle;
    packet_state <= S1;
    fifo_usb_tx_clr <= '1';
   else
    case usb_io_state is
     when usb_io_idle =>
      packet_state <= S1;
      -- Look for incoming data first; then outgoing.
      if(ftdi_usb_rxf_n = '0') then
       usb_io_state <= usb_io_rx;
      elsif(fifo_usb_tx_empty = '0') then
       fifo_usb_tx_rd <= '1';
       usb_io_state <= usb_io_tx;
      else
      end if;
     when usb_io_tx =>
      if(ftdi_usb_txe_n = '0') then
       case packet_state is
        when S1 =>
         ftdi_usb_bus_out <= X"AA";
         packet_state <= S2;
        when S2 =>
         ftdi_usb_wr_n <= '0';
         packet_state <= S3;
        when S3 =>
         ftdi_usb_bus_out <= fifo_usb_tx_bus(23 downto 16);
         packet_state <= S4;
        when S4 =>
         packet_state <= S5;
        when S5 =>
         ftdi_usb_bus_out <= fifo_usb_tx_bus(15 downto 8);
         packet_state <= S6;
        when S6 =>
         packet_state <= S7;
        when S7 =>
         ftdi_usb_bus_out <= fifo_usb_tx_bus(7 downto 0);
         packet_state <= S8;
        when S8 =>
         packet_state <= S1;
        when others =>
         packet_state <= S1;
       end case;
      end if;
     when usb_io_rx =>
      -- Not yet implemented --
      packet_state <= S1;
    end case;
   end if; -- reset
  end if; -- rising_edge
 end process USB_IO_Handler;
end architecture rtl;
    Sorry to reply to my own post, but I just saw a similar thread which suggests that the bad state could be related to timing (perhaps with the ftdi_usb_txe_n input?).
    I'm trying to use the FTDI FT2232 USB chip in asynchronous mode. That may be the source of all of my problems....
    If the incoming signals are asynchrnous, I suggest you synchronise them to the "main_clk" before trying to use them. Without doing that, you will be violating setup and hold times, and any signals that read them may become meta-stable.
    Metastability isn't required to get illegal states. Routing delay skew is sufficient, causing 99.9% (or so) of unexpected logic behaviour with timing violations. Synchronizing is the solution anyway.
    change your clk to 24Mhz and use this (LMK if it helps):
    -- ft2232d_fifo generation
    library ieee;
    use ieee.std_logic_unsigned.all;
    entity ft2232d_fifo is
    port (
    clkin : in std_logic; -- 24 MHZ clock from oscillator
    resetn : in std_logic; -- global reset to reset everything
    usbtxen : in std_logic; -- TX FIFO empty (low means data can go into FIFO)
    usbrxfn : in std_logic; -- RX FIFO full (low means data can be read from FIFO)
    readfifodata : in std_logic; -- Read Enable
    writefifo : in std_logic; -- Write Enable
    usbrdn : out std_logic; -- strobe low-then-high to get data from FIFO
    usbwr : out std_logic; -- strobe high-then-low to write data into FIFO
    usbd : inout std_logic_vector(7 downto 0); -- bi-directional data bus to FIFO chip
    data_read : out std_logic_vector(7 downto 0); -- bi-directional data bus to FIFO chip
    data_write : in std_logic_vector(7 downto 0) -- bi-directional data bus to FIFO chip
    end ft2232d_fifo;
    architecture rtl of ft2232d_fifo is
    type USB_STATE_TYPE is (USBIDLE,USBGETBYTE,USBSAVEBYTE,
    USBRDDN,USBPUTBYTE,USBWOUT,
    USBWHLD);
    --signal USBState : std_logic_vector(4 downto 0);
    --signal USBIDLE : std_logic_vector(4 downto 0) := "00000";
    --signal USBGETBYTE : std_logic_vector(4 downto 0) := "00001";
    --signal USBSAVEBYTE : std_logic_vector(4 downto 0) := "10001";
    --signal USBRDDN : std_logic_vector(4 downto 0) := "01000";
    --signal USBPUTBYTE : std_logic_vector(4 downto 0) := "00010";
    --signal USBWOUT : std_logic_vector(4 downto 0) := "00110";
    --signal USBWHLD : std_logic_vector(4 downto 0) := "01100";
    signal USBState : USB_STATE_TYPE;
    signal iswrite : std_logic;
    signal usbdone : std_logic;
    begin
    --usbrdn <= NOT USBState(0);
    --usbwr <= USBState(1);
    --iswrite <= USBState(2);
    --usbdone <= USBState(3);
    usb_rx_tx: process (resetn,clkin)
    begin
    if (resetn = '0') then
    USBState <= USBIDLE;
    usbrdn <= '1';
    usbwr <= '0';
    iswrite <= '0';
    usbdone <= '0';
    data_read <= (others => '0');
    elsif (rising_edge(clkin)) then
    case USBState is
    when USBIDLE =>
    usbrdn <= '1';
    usbwr <= '0';
    iswrite <= '0';
    usbdone <= '0';
    if(readfifodata = '1' AND usbrxfn = '0') then
    USBState <= USBGETBYTE;
    elsif(writefifo = '1' AND usbtxen = '0') then
    USBState <= USBPUTBYTE;
    else
    end if;
    when USBGETBYTE =>
    usbwr <= '0';
    iswrite <= '0';
    usbdone <= '0';
    usbrdn <= '0';
    USBState <= USBSAVEBYTE;
    when USBSAVEBYTE =>
    usbwr <= '0';
    iswrite <= '0';
    usbdone <= '0';
    usbrdn <= '0';
    if(readfifodata = '1')then
    data_read <= usbd;
    end if;
    USBState <= USBRDDN;
    when USBRDDN =>
    usbrdn <= '1';
    usbwr <= '0';
    iswrite <= '0';
    usbdone <= '1';
    if(readfifodata = '0' AND writefifo = '0')then
    end if;
    when USBPUTBYTE =>
    usbrdn <= '1';
    usbwr <= '1';
    iswrite <= '0';
    usbdone <= '0';
    USBState <= USBWOUT;
    when USBWOUT =>
    usbrdn <= '1';
    usbwr <= '1';
    iswrite <= '1';
    usbdone <= '0';
    USBState <= USBWHLD;
    when USBWHLD =>
    usbrdn <= '1';
    usbwr <= '0';
    iswrite <= '1';
    usbdone <= '1';
    end if;
    end case;
    end if;
    end process usb_rx_tx;
    usbd <= data_write when (iswrite) = '1' else "ZZZZZZZZ";
    end rtl;
    Using FT2232 in asynchronous mode with 24 MHz clock frequency does not solve the problem addressed in post# 2 to# 4. Synchroniszation is still required as long as FTDI internal and FPGA clock ar unrelated.
