14 years agochange your clk to 24Mhz and use this (LMK if it helps):
-- ft2232d_fifo generation library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_unsigned.all; entity ft2232d_fifo is port ( clkin : in std_logic; -- 24 MHZ clock from oscillator resetn : in std_logic; -- global reset to reset everything usbtxen : in std_logic; -- TX FIFO empty (low means data can go into FIFO) usbrxfn : in std_logic; -- RX FIFO full (low means data can be read from FIFO) readfifodata : in std_logic; -- Read Enable writefifo : in std_logic; -- Write Enable usbrdn : out std_logic; -- strobe low-then-high to get data from FIFO usbwr : out std_logic; -- strobe high-then-low to write data into FIFO usbd : inout std_logic_vector(7 downto 0); -- bi-directional data bus to FIFO chip data_read : out std_logic_vector(7 downto 0); -- bi-directional data bus to FIFO chip data_write : in std_logic_vector(7 downto 0) -- bi-directional data bus to FIFO chip ); end ft2232d_fifo; ------------------------------------------------------------- architecture rtl of ft2232d_fifo is type USB_STATE_TYPE is (USBIDLE,USBGETBYTE,USBSAVEBYTE, USBRDDN,USBPUTBYTE,USBWOUT, USBWHLD); --signal USBState : std_logic_vector(4 downto 0); --signal USBIDLE : std_logic_vector(4 downto 0) := "00000"; --signal USBGETBYTE : std_logic_vector(4 downto 0) := "00001"; --signal USBSAVEBYTE : std_logic_vector(4 downto 0) := "10001"; --signal USBRDDN : std_logic_vector(4 downto 0) := "01000"; --signal USBPUTBYTE : std_logic_vector(4 downto 0) := "00010"; --signal USBWOUT : std_logic_vector(4 downto 0) := "00110"; --signal USBWHLD : std_logic_vector(4 downto 0) := "01100"; signal USBState : USB_STATE_TYPE; signal iswrite : std_logic; signal usbdone : std_logic; begin --usbrdn <= NOT USBState(0); --usbwr <= USBState(1); --iswrite <= USBState(2); --usbdone <= USBState(3); usb_rx_tx: process (resetn,clkin) begin if (resetn = '0') then USBState <= USBIDLE; usbrdn <= '1'; usbwr <= '0'; iswrite <= '0'; usbdone <= '0'; data_read <= (others => '0'); elsif (rising_edge(clkin)) then case USBState is when USBIDLE => usbrdn <= '1'; usbwr <= '0'; iswrite <= '0'; usbdone <= '0'; if(readfifodata = '1' AND usbrxfn = '0') then USBState <= USBGETBYTE; elsif(writefifo = '1' AND usbtxen = '0') then USBState <= USBPUTBYTE; else USBState <= USBIDLE; end if; when USBGETBYTE => usbwr <= '0'; iswrite <= '0'; usbdone <= '0'; usbrdn <= '0'; USBState <= USBSAVEBYTE; when USBSAVEBYTE => usbwr <= '0'; iswrite <= '0'; usbdone <= '0'; usbrdn <= '0'; if(readfifodata = '1')then data_read <= usbd; end if; USBState <= USBRDDN; when USBRDDN => usbrdn <= '1'; usbwr <= '0'; iswrite <= '0'; usbdone <= '1'; if(readfifodata = '0' AND writefifo = '0')then USBState <= USBIDLE; end if; when USBPUTBYTE => usbrdn <= '1'; usbwr <= '1'; iswrite <= '0'; usbdone <= '0'; USBState <= USBWOUT; when USBWOUT => usbrdn <= '1'; usbwr <= '1'; iswrite <= '1'; usbdone <= '0'; USBState <= USBWHLD; when USBWHLD => usbrdn <= '1'; usbwr <= '0'; iswrite <= '1'; usbdone <= '1'; if(readfifodata = '0' AND writefifo = '0')then USBState <= USBIDLE; end if; end case; end if; end process usb_rx_tx; usbd <= data_write when (iswrite) = '1' else "ZZZZZZZZ"; end rtl; -------------------------------------------------------------
