VHDL Question
[INDENT]I'm trying to create a square wave and I'm converting code from verilog and im getting the below error. Any help would be great thanks
Error (10327): VHDL error at SquareWave.vhd(36): can't determine definition of operator ""-"" -- found 0 possible definitions
[CODE]
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
ENTITY SquareWave IS
PORT (
clk : IN std_logic;
rst_n : IN std_logic;
sq_wave : OUT std_logic
END SquareWave;
ARCHITECTURE BEHAVORIAL OF SquareWave IS
-- Input clock is 400Hz
signal CLOCK_FREQUENCY : Time := 2500000 ns;
signal sq_wave_reg : std_logic := '0';
begin
sq_wave <= sq_wave_reg;
process (clk)
-- Counter for toggling of clock
variable counter : integer;
begin
if (rst_n /= rst_n) then
counter := 8;
sq_wave_reg <= '1';
else
-- If counter is zero, toggle sq_wave_reg
if (counter = 8) then
sq_wave_reg <= sq_wave_reg;
-- Generate 1Hz Frequency
counter := CLOCK_FREQUENCY/2 - 1;
-- Else count down
else
counter <= counter - 1;
end if;
end if;
end process;
END BEHAVORIAL;
counter is a variable, so you should have := instead of <= like you did just above.
I'm afraid your code is completely broken and would not work in any language. A VHDL process is not the same as a verilog always@. You need to wait on the clk. sq_wave_reg is not a register.
When do you expect "if (rst_n /= rst_n) then" to be true? You probably meant "if rst_n = '0' then" You never change sq_wave_reg. You probably mean "sq_wave_reg <= not sq_wave_reg;" Is this supposed to be synthesizable? Your comments say you want a 1 Hz wave from a 400 Hz clock. That means you should toggle every 200 clock cycles. Your CLOCK_FREQUENCY is meaningless. - Altera_Forum
Here is a sawtooth wave I found, i'm trying to get a 400Hz square wave, it compiles, any help will be appreciated. Thanks
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity SquareWave is port (clk : in std_logic; wave_out : out std_logic_vector(7 downto 0); reset :in std_logic ); end SquareWave; architecture Behavioral of SquareWave is signal count : integer := 0; begin process(clk,reset) begin if(reset = '1') then count <= 0; elsif(rising_edge(clk)) then if(count = 10000000000) then count <= 0; else count <= count + 1; end if; end if; end process; wave_out <= conv_std_logic_vector(count,8); end Behavioral; - Altera_Forum
Check your warnings. You have "count" (a 32-bit integer) going to ten billion. This is not a sensible way to make sawtooth wave in any event.
You seem to want to do this without even a basic understanding of VHDL. Find a good tutorial on VHDL and learn it. Then making a square wave will be trivial. I'm afraid my favorite VHDL books are all out of print, but there are good ones out there. - Altera_Forum
search for books on this forum then you'll find recommendations
chjones2008, sorry if my comments came across as a bit terse. The intent was to be helpful. It's been a while, but I had a terrible time learning VHDL at first. The key for me, coming from C/C++, was understanding that VHDL is creating hardware and to think in terms of flip-flops and combinational logic. The two books that helped:
"HDL Chip Design" by Douglas J Smith "Essential VHDL RTL Synthesis Done Right" by Sundar Rajan Many VHDL books are voluminous tomes on the language. These are Kernighan&Ritche like and help incrementally learn the language and show what logic a given bit of code with synthesize.
