17 years ago
VHDL question
Hey, I'm using an MCP4922 DAC chip and I'm programming it using VHDL.
The chip has 16 bits, 4 which I want to be constant and the other 12 will be keep changing.
My idea is to make 2 vectors (4 bits and 12 bits) then combine them into one 16 bit vector and send that to my DAC.
However, I'm not quite sure what my code should look like, can anyone help me with that?
Note: the constant bits are always 12 though 15.
1 Reply
    not quite sure, if this adresses your question, but you can either define vectors e.g.
    CONSTANT Const : STD_LOGIC_VECTOR (3 DOWNTO 0) := "xxxx"; --place bits here
    SIGNAL Changing : STD_LOGIC_VECTOR (11 DOWNTO 0); -- changing Bits
    SIGNAL Data_to_DAC : STD_LOGIC_VECTOR (15 DOWNTO 0); -- Data to be sent to DAC
    and combine the Data_to_DAC prior sending it to the DAC by
    Data_to_DAC <= Constant&Changing;
    this results in Bit 15..12 of Data_to_DAC are Bit 3..0 of Const and Bit 11..0 of Data_to_DAC being Bit 11..0 of Changing with the constant bits being defined in the upper section of the VHDL code.
    Other way is to define only Data_to_DAC with assignment in code being
    Data_to_DAC (15 DOWNTO 12) <= "xxxx"; -- place the constant bits here Data_to_DAC (11 DOWNTO 0) <= Changing; -- or direct the signal which shall be sent
    All roads lead to Rome...
    Sincerely, Carlhermann
