CStra20
6 years agoVHDL pragma --synthesis library ... is unsupported in 20.1 ?
See below the output. First line of bsv_pkg.vhd is the embedded pragma --synthesis library bsv This pragma works in previous version of quartus. Info: **********************************************...
Isaac_V_Intel
Contributor
6 years agoHi CStra20,
First some questions to get all the ground of your case.
Did you have W/R permissions to the path that you are using at the project?
Can you try to specify the library in the qsf line that adds the file to the project.
Can you share your project with us to replicate this issue, in case that you can't solve this.
Best regards
Isaac Vazquez
