16 years ago
VHDL "others" problem
Hi, this is my first post on this forum.
I have a problem when compiling this code with Quartus II 8.0 web edition:
type tag_array is array (0 to 255) of std_logic_vector(7 to 0); -- tipo per il campo TAG
signal TAG :tag_array;
TAG<= (others=>'0');
The compilation fails on the last line (TAG<= (others=>'0');)
I have found this code on internet and and I try to understand
because it doesn't work.
    you should write
    TAG<= (others => (others=>'0'));
    or
    TAG<= (others=>"00000000");
    since it is two _D signal
    edit:
    you got another mistake here:
