11 years agoVHDL, MSF 5 bit counter
Hello everyone,
I'm an italian student, so I apologize for my english, and I'm new in the forum, I have to do an exercise: the creation by MSF of a 5-bit counter using VHDL. I have various input signals: a STOP signal which stops the count at the moment, a RESTART signal that resume the count, an UP_DOWN signal to choose the direction of the count and the signal of RESET. I have alse 3 output signals: a signal END_C which indicates the end of the count, a signal START_C which indicates the start and a Q signal which indicates the value of the count. This is my VHDL code:library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity esercizio3 is
port(CK, stop, restart, reset, up_down: in std_logic;
end_c, start_c: out std_logic;
Q: out std_logic_vector(4 downto 0));
end esercizio3;
architecture arc of esercizio3 is
type stato is(ST0, ST1, ST2, ST3);
signal ps, ns: stato;
signal temp: std_logic_vector(4 downto 0);
begin
seq_proc: process(CK, RESET)
begin
if(RESET='0')then
ps<=ST0;
elsif(rising_edge(CK)) then
ps<=ns;
end if;
end process seq_proc;
comb_proc:process(RESTART, STOP, UP_DOWN, PS)
begin
end_c<='0';
start_c<='0';
case ps is
when ST0=>
temp<="00000";
if(stop='0')then
ns<=ST0;
elsif(up_down='0')then
ns<=ST1;
else
ns<=ST2;
end if;
when ST1=>
temp<=temp-"00001";
if(stop='0')then
ns<=ST3;
ns<=ST1;
else
ns<=ST2;
end if;
when ST2=>
temp<=temp+"00001";
if(stop='0')then
ns<=ST3;
elsif(up_down<='0')then
ns<=ST1;
else
ns<=ST2;
end if;
when ST3=>
if(Restart='1')then
ns<=ST3;
ns<=ST1;
else
ns<=ST2;
end if;
when others=>
ns<=ST0;
end case;
Q<=temp;
if(temp="00000")then
start_c<='1';
elsif(temp="11111")then
end_c<='1';
end if;
end process comb_proc;
end arc; The compilation is successful but I get an error in model sim which is: # **Error: (vsim-3601) Iteration limit reached at time 15ns. I suppose there is a loop that does not allow proper execution. Can you help me fix it? Thanks you.3 Replies
The problem is you have counters in the asynchronous code. If you think about it, for a real circuit, you're asking it to build an adder that loops back on itself with 0 delay, meaning it's trying to count up or down an infinite number of times in an infinitely small amount of time. Hence the infinite loop.
You need to move the counter into a clocked process - Altera_Forum
Ok so i have an infinite loop but how can I move the counter into a cloked process?? Can you please write me a couple of code strings, because this is the first time I realze a MSF using VHDL and I'm not practical with it??
Thanks you. - Altera_Forum
Have the state machine generate a counter whale signal and another clocked process that describes the counter. There are plenty of examples out there for a clicked process with enable.
