jrrguzman
8 years agoVHDL model for ALTCLKCTRL not generated
Hi, I'm trying to simulate a design with an ALTCLKCTRL clock buffer in it. However, I can't get QSYS to generate the VHDL simulation model. It only does generate Verilog, not matter what settings I ...
jrrguzman
8 years agoHi,
Well the issue is not resolved since the tool does not generate the right component model. Yes, I get the .vhd file under simulation but not the right submodule which should be generated along. I wonder if you have tried to simulate the generated IP on Modelsim.
However I'm moving on since I am able to work with the simulation model from v18.0.
Thanks for the time.
