12 years ago
VHDL latches
I have a warnings in Quartus:
Warning (10631): VHDL Process Statement warning at dma.vhd(449): inferring latch(es) for signal or variable "din_exp", which holds its previous value in one or more paths through the process
Warning (10631): VHDL Process Statement warning at salsa_dma.vhd(449): inferring latch(es) for signal or variable "const_exp", which holds its previous value in one or more paths through the process
Suspicious code is looks like this:
SIGNAL din_exp, const_exp : STD_LOGIC_VECTOR(511 DOWNTO 0) ;
PROCESS(state, const, dout, ram_dout, data_in, din_exp, const_exp, din)
     VARIABLE din_exp_var, const_exp_var : STD_LOGIC_VECTOR(511 DOWNTO 0) ;
    BEGIN
        CASE state IS
            WHEN idle_state =>
                din_exp_var := data_in(511 DOWNTO 0) XOR data_in(1023 DOWNTO 512) ;
                const_exp_var := data_in(511 DOWNTO 0) XOR data_in(1023 DOWNTO 512) ;
            WHEN s0_1 =>
                 din_exp_var := const XOR dout ;
                 const_exp_var := const XOR dout ;
            WHEN s1 =>
                 din_exp_var := din_exp ;
                 const_exp_var := const_exp ;
             -- other states
            WHEN OTHERS =>
        END CASE ;
             din_exp <= din_exp_var ;
             const_exp <= const_exp_var ;
END PROCESS ;
In state s1 I don't want to change anything to my signal assignment, also previous values must be saved. There are no default values for these signals. Is there a latch needed? Is this code ok? Or should I change anything? How?
Thank you!
    When want a signal hold its value until some condition occurs, you should use register instead of latches. Registers needs a clock signal. You may modify your code this way:
    process(clk,clr)
    begin
    if(clr='1') then
    din_reg <= din_next;
    elsif(clk'event and clk='1')then
    end if;
    end process;
    PROCESS(...)
    din_next <= din_reg;
    BEGIN
    CASE state IS
    WHEN idle_state =>
    din_next <= data_in(511 DOWNTO 0) XOR data_in(1023 DOWNTO 512) ;
    WHEN s0_1 =>
    din_next <= const XOR dout ;
    WHEN s1 =>
    din_next <= din_exp ;
    WHEN OTHERS =>
    END CASE ;
    END PROCESS ;
    The same for the rest of signals.
    I think you've messed up your code a little bertulus. din_reg <= din_next should be assigned inside the clock. also, din_next <= din_reg should be inside the begin.
    Or make life even easier for yourself and others - use a single process clocked state machine (not 2).
    oh yes, i place this assigment in the wrong line. Sorry linas.
    Tricky, about writing sequential circuits in 1 or 2 blocks, theorically there are no difference in the description. But , it makes difference writting in 1 or 2 blocks in the Quartus tool? For example, a counter written in 1 block, infers a better circuit ( fewer LEs or a faster implementation) ?
    As I understand it, the two process style comes from the days when people (and tools) required separate processes for sequential logic and registers. And its a style thats never gone away. For beginners (and others) it is prone to latches.
    Using a single clocked process removes these problems, and tools have no problems understanding them. I have no doubts you will get the same results with both (or if anything, you will get minor usage differences).
    For me, a single process is more readible (and its all about readbility - not minor quibbles over 1 or 2 luts).
    I, often, use the 2 block style for state machines when I wish to write conditions like
    "if state_current = SOME_STATE and state_next = SOME_OTHER_STATE then ....".
    Other than that, I also prefer the 1 block style.
    And implementation wise, it's the same.
    Thank you all for help and useful tips. I didn't modify this part much, just removed states with latches. I implemented registers in component one level down in the hierarchy, now everything looks ok.
