VHDL: Initial values for (unconnected) input ports are ignored (Quartus Prime 20.2 Pro)
- Just to clarify what you're saying, you've always had those initial values set for the 3 ports, but you always left them unconnected when instantiating counter_32updnld elsewhere. Is that accurate?
Yes, that's correct. For example, I created a block symbol file (.bsf), added that symbol to my top-level block diagram/schematic file (.bdf) and left those 3 ports unconnected:
counter_32updnld in TopLevel Design
Using that in Quartus Prime 19.4 Pro or 20.2 Pro the counter does nothing in that case. If I connect the ports "clk_en" and "cnt_en" to "vcc" in TopLevel, the counter works but counts downwards (as the port "up/n_dn" is left unconnected).
- What was the last version of the software you used where it worked correctly?
I just tried the same instantiation in another project using Quartus Prime Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition and checked the correct behaviour of the counter in the programmed device (Cyclone IV).
So moving from Lite/Standard to Pro could certainly be the issue here. Synthesis in Pro has more stringent checks than Lite/Standard so you may not be able to do this in Pro (though there should be some type of warning message; can you double-check to see if you missed any messages or check the compilation report?).
If you're only using a schematic for the upper-level design (instead of HDL coding), I'm not sure what kind of checks are done at the higher level. Can you try the same design but instantiate the counter in HDL code instead of a schematic? Leave the entries in the PORT MAP empty or use the OPEN option in the mapping (for example, updown => open).
#iwork4intel
- HBirk6 years ago
I did a test with instantiating the counter inside a vhdl file (wrapper_#), created a symbol file for that wrapper (which I had to do in Lite Edidion as Pro Edition didn't support that) and connected it in my project's TopLevel schematic.
I did that in 2 ways:
- wrapper_01:
- Ports "sload", "data", "clock", "aclr", "q" and "cout" are mapped to corresponding PORT MAP entries of counter_32updnld.
- No entries in PORT MAP of counter_32updnld called "updown", "clk_en", and "cnt_en"
- wrapper_02:
- additional ports to toplevel called "updown", "clk_en", and "cnt_en"; these ports were left unconnected in TopLevel.
- Mapped these ports in the PORT MAP of counter_32updnld to the entries "updown", "clk_en", and "cnt_en"
Result:
Wrapper_01 counts upwards, wrapper_02 doesn't count at all.
If I connect wrapper_02 ports "clk_en" and "cnt_en" to vcc in TopLevel, it counts downwards.So it seems to me that ports in schematics are treaded differently in Lite and Pro Edition of Quartus Prime.
- wrapper_01:
