8 years agoVHDL help with code
Hi! Can anyone help me ih writing VHDL code for this diagra? I need simulation results too. Thanks ! :))
8 years agookey so tell me what is A1 A2 etc. Input or Output ? I have some code but i don't understand it... I really need this... Please help me ;c
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity projekt is port(Up,Down, : in std_logic; A0, A1, A2, A3: out std_logic); end projekt; architecture przerzutnik of projekt is component T_FF is port (T: in std_logic Clock: in std_logic Out: out std_logic); signal tmp: std_logic; begin process (Clock) begin if Clock'event and Clock='1' then if T='0' then tmp <= tmp; elsif T='1' then tmp <= not (tmp); end if; end if; end process; Out <= tmp; end przerzutnik; begin T_FF: T1 port map(T T_FF: T2 port map T_FF: T3 port map T_FF: T4 port map
