13 years ago
VHDL Help for Counter
I have to make a counter and I'm a little bit lost, any help is appreciated!
variables:
inputs:
Enable - 2 bit vector
Clock - 1 bit - 1000 Hz.
Hold - 2 bit vector
Reset - 1 bit
outputs:
Out_H - 1 bit
Out_L - 1 bit
Here is the way it needs to work:
It needs to count to ten seconds based on the 1000 Hz input clock. It needs to have a reset, which is already in the file. However, a few things are different: The output[ clk_temp] in the file is our Out_H (active high). You need to make an Out_L which is the active low version of that. Also, you need to change it so that it will only count and so that Out_H can only possibly be 1 when both bits of Enable[Enable[0] and Enable[1]] are equal to 1. And in the part where it flips the output(clk_temp <= not clk_temp) make it so that it will only flip it if the counter has counted all the way to ten seconds AND neither bit in Hold is 1(both are 0).
    Heres what I have as of now, still getting a decent amound of errors and I'm having trouble dealing with two enables and I'm not really sure how to treat the hold function. Any help is greatly appreciated.
    -- Company:
    -- Engineer:
    -- Create Date: 13:38:57 11/24/2012
    -- Design Name:
    -- Module Name: Counter_2 - Behavioral
    -- Project Name:
    -- Target Devices:
    -- Tool versions:
    -- Description:
    -- Dependencies:
    -- Revision:
    -- Revision 0.01 - File Created
    -- Additional Comments:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    -- Uncomment the following library declaration if using
    -- arithmetic functions with Signed or Unsigned values
    --use IEEE.NUMERIC_STD.ALL;
    -- Uncomment the following library declaration if instantiating
    -- any Xilinx primitives in this code.
    --library UNISIM;
    --use UNISIM.VComponents.all;
    entity Counter_2 is
    Port ( E1 : in STD_LOGIC;
    E2 : in STD_LOGIC;
    Clk : in STD_LOGIC;
    Hold : in STD_LOGIC_VECTOR (1 downto 0);
    Reset : in STD_LOGIC;
    Out_H : out STD_LOGIC;
    Out_L : out STD_LOGIC);
    end Counter_2;
    architecture Behavioral of Counter_2 is
    signal clk_temp1 : std_logic;
    signal clk_temp2 : std_logic;
    signal count : integer range 0 to 10000 := 0;
    signal enable : std_logic;
    begin
    enable <= E1 and E2;
    process (clk, reset, count, hold)
    begin
    if (reset = '1') then
    clk_temp1 <= '0';
    clk_temp2 <= '0';
    count <= 0;
    elsif (clk ='1' and clk'event) then
    if (hold = '1') then
    count <= count+1;
    else
    if (count = 1) then
    clk_temp1 <= not clk_temp1;
    clk_temp2 <= not clk_temp2;
    count <= 0;
    end if;
    if (rising_edge(enable)) then
    count <= 10000;
    elsif (rising_edge(clk)) then
    if count > 0 then
    Out_H <= '1';
    Out_L <= '0';
    count <= count -1;
    elsif count = 0 then
    Out_H <= '0';
    Out_L <= '1';
    end if;
    end if;
    end if;
    end if;
    end process;
    Out_H <= clk_temp1;
    Out_L <= clk_temp2;
    end Behavioral;
    what errors are you getting?
    Plus I notice this appears to have been generated using a Xilinx template - you realise this is an Altera Forum?
