nadav12_batito
2 years agovhdl error
i neep to plan counter bcd library ieee; use ieee.std_logic_1164.all; entity h145 is port ( resetn: in std_logic; clk: in std_logic; sclear: in std_logic; cep, cet: in std_logic; qout: buff...
- 2 years ago
Looks like you're trying to synthesize your test bench, which makes no sense. Are you trying to synthesize or simulate? The test bench is for simulation only. Whereas for synthesis the top level should be entity h145 without the test bench.
roeekalinsky
Contributor
2 years agoLooks like you're trying to synthesize your test bench, which makes no sense. Are you trying to synthesize or simulate? The test bench is for simulation only. Whereas for synthesis the top level should be entity h145 without the test bench.
nadav12_batito
2 years agoi want to write test bench for pogram h145
