8 years ago
VHDL code error
https://alteraforum.com/forum/attachment.php?attachmentid=15816&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15818&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15819&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15820&stc=1 Hello,
I am trying to do Bit Error Rate Testor on my FPGA Altera Cyclone V board and SFP-HSMC. I am trying to send 3Gbps of data where as the maximum the transceiver or receiver can send or receive is 3.25Gbps. I am getting few errors which I am not able to figure out where the error exactly is. I request you to please let me know what changes do I need to make in the code.
Thanks a ton in advance.
    Hello, I am attaching rest of the code here. Sorry about that.
    Test Bench code:
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    -- Uncomment the following library declaration if using
    -- arithmetic functions with Signed or Unsigned values
    --USE ieee.numeric_std.ALL;
    ENTITY bertb IS
    END bertb;
    ARCHITECTURE behavior OF bertb IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT BERCalculator
    PORT(
    ------------ Clock ----------------------
    CLK_IN : in std_logic;
    Key : in std_logic_vector (3 downto 0);
    ------------ SEG7 -----------------------
    HEX0 : out std_logic_vector (7 downto 0);
    HEX1 : out std_logic_vector (7 downto 0);
    HEX2 : out std_logic_vector (7 downto 0);
    HEX3 : out std_logic_vector (7 downto 0);
    ----------- Received_Signals -------------
    RX_Received : in std_logic_vector (255 downto 0);
    TX_Transmitted : in std_logic_vector (175 downto 0)
    END COMPONENT;
    --Inputs
    signal CLK_IN : std_logic := '0';
    signal key : in std_logic_vector (3 downto 0) := (others => '1');
    signal RX_Received : in std_logic_vector (255 downto 0);
    signal TX_Transmitted :in std_logic_vector (175 downto 0)
    --Outputs
    signal HEX0 : =out std_logic_vector (7 downto 0);
    signal HEX1 : out <=std_logic_vector (7 downto 0);
    signal HEX2 : out <=std_logic_vector (7 downto 0);
    signal HEX3 : out <=std_logic_vector (7 downto 0);
    -- Clock period definitions
    constant clock_period : time := 20 ns;
    BEGIN
    -- Instantiate the Unit Under Test (UUT)
    uut: up_down_counter PORT MAP (
    CLK_IN => CLK_IN,
    key => key,
    RX_Received => RX_Received,
    HEX0=> HEX0,
    HEX1=> HEX1,
    HEX2=> HEX2,
    HEX3=> HEX3,
    TX_Transmitted => TX_Transmitted
    -- Clock process definitions
    clock_process :process
    begin
    CLK_IN <= '0';
    wait for clock_period/2;
    CLK_IN <= '1';
    end process;
    -- Stimulus process
    stim_proc: process
    begin
    -- hold reset state for 100 ns.
    RX_Received: in std_logic_vector (255 downto 0):= (others => '0');
    wait for 200 ns;
    RX_Received: in std_logic_vector (255 downto 0):= (others => '1');
    wait for 100 ns;
    TX_Received: in std_logic_vector (175 downto 0):= (others => '1');
    wait for 100 ns;
    TX_Received: in std_logic_vector (175 downto 0):= (others => '0');
    end process;
    END;
    --- Quote Start ---
    --Inputs
    --Outputs
    --- Quote End ---
    signal doesn`t required direction.
    --- Quote Start ---
    clock_process rocess
    --- Quote End ---
    clock_process : process
    --- Quote Start ---
    stim_proc: process
    begin
    wait for 200 ns;
    wait for 100 ns;
    wait for 100 ns;
    end process;
    --- Quote End ---
    Modify like below,
    RX_Received <= (others => '0');
    I would suggest go through the online training & check the attached modified code,
    https://www.altera.com/support/training/course/ohdl1110.html
    LIBRARY ieee;USE ieee.std_logic_1164.ALL;
    ENTITY bertb IS
    END bertb;
    PORT(
    END COMPONENT;
    --Inputs
    signal key :  std_logic_vector (3 downto 0) := (others => '1');
    signal RX_Received    :  std_logic_vector (255 downto 0);
    signal TX_Transmitted    : std_logic_vector (175 downto 0);
    --Outputs
    signal HEX0 :  std_logic_vector (7 downto 0);
    signal HEX1 :  std_logic_vector (7 downto 0);
    signal HEX2 :  std_logic_vector (7 downto 0);
    signal HEX3 :  std_logic_vector (7 downto 0);
    BEGIN
    CLK_IN => CLK_IN,
    key => key,
    HEX0=> HEX0,
    HEX1=> HEX1,
    HEX2=> HEX2,
    HEX3=> HEX3,
    begin
    CLK_IN <= '0';
    CLK_IN <= '1';
    end process;
    -- Stimulus process
    stim_proc: process
    begin
    wait for 200 ns;
    RX_Received <= (others => '1');
    wait for 100 ns;
    TX_Transmitted <= (others => '1');
    wait for 100 ns;
    TX_Transmitted <= (others => '0');
    end process;
    END;
    Best Regards
    Vikas Jathar
    Have you resolved the issue?
    Best Regards
    Vikas Jathar
