8 years agoVHDL code error
https://alteraforum.com/forum/attachment.php?attachmentid=15816&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15818&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=1...
8 years agoHello, I am attaching rest of the code here. Sorry about that.
Test Bench code: LIBRARY ieee; USE ieee.std_logic_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --USE ieee.numeric_std.ALL; ENTITY bertb IS END bertb; ARCHITECTURE behavior OF bertb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT BERCalculator PORT( ------------ Clock ---------------------- CLK_IN : in std_logic; Key : in std_logic_vector (3 downto 0); ------------ SEG7 ----------------------- HEX0 : out std_logic_vector (7 downto 0); HEX1 : out std_logic_vector (7 downto 0); HEX2 : out std_logic_vector (7 downto 0); HEX3 : out std_logic_vector (7 downto 0); ----------- Received_Signals ------------- RX_Received : in std_logic_vector (255 downto 0); TX_Transmitted : in std_logic_vector (175 downto 0) ); END COMPONENT; --Inputs signal CLK_IN : std_logic := '0'; signal key : in std_logic_vector (3 downto 0) := (others => '1'); signal RX_Received : in std_logic_vector (255 downto 0); signal TX_Transmitted :in std_logic_vector (175 downto 0) --Outputs signal HEX0 : =out std_logic_vector (7 downto 0); signal HEX1 : out <=std_logic_vector (7 downto 0); signal HEX2 : out <=std_logic_vector (7 downto 0); signal HEX3 : out <=std_logic_vector (7 downto 0); -- Clock period definitions constant clock_period : time := 20 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: up_down_counter PORT MAP ( CLK_IN => CLK_IN, key => key, RX_Received => RX_Received, HEX0=> HEX0, HEX1=> HEX1, HEX2=> HEX2, HEX3=> HEX3, TX_Transmitted => TX_Transmitted ); -- Clock process definitions clock_process :process begin CLK_IN <= '0'; wait for clock_period/2; CLK_IN <= '1'; wait for clock_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. RX_Received: in std_logic_vector (255 downto 0):= (others => '0'); wait for 200 ns; RX_Received: in std_logic_vector (255 downto 0):= (others => '1'); wait for 100 ns; TX_Received: in std_logic_vector (175 downto 0):= (others => '1'); wait for 100 ns; TX_Received: in std_logic_vector (175 downto 0):= (others => '0'); end process; END;
