8 years agoVHDL code error
https://alteraforum.com/forum/attachment.php?attachmentid=15816&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15818&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=1...
8 years agoHi,
--- Quote Start --- --Inputs signal CLK_IN : std_logic := '0'; signal key : in std_logic_vector (3 downto 0) := (others => '1'); signal RX_Received : in std_logic_vector (255 downto 0); signal TX_Transmitted :in std_logic_vector (175 downto 0) --Outputs signal HEX0 : =out std_logic_vector (7 downto 0); signal HEX1 : out <=std_logic_vector (7 downto 0); signal HEX2 : out <=std_logic_vector (7 downto 0); signal HEX3 : out <=std_logic_vector (7 downto 0); --- Quote End --- signal doesn`t required direction. --- Quote Start --- clock_process rocess --- Quote End --- clock_process : process --- Quote Start --- stim_proc: process begin -- hold reset state for 100 ns. RX_Received: in std_logic_vector (255 downto 0):= (others => '0'); wait for 200 ns; RX_Received: in std_logic_vector (255 downto 0):= (others => '1'); wait for 100 ns; TX_Received: in std_logic_vector (175 downto 0):= (others => '1'); wait for 100 ns; TX_Received: in std_logic_vector (175 downto 0):= (others => '0'); end process; --- Quote End --- Modify like below, RX_Received <= (others => '0'); I would suggest go through the online training & check the attached modified code, https://www.altera.com/support/training/course/ohdl1110.htmlLIBRARY ieee;USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY bertb IS
END bertb;
ARCHITECTURE behavior OF bertb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT BERCalculator
PORT(
------------ Clock ----------------------
CLK_IN : in std_logic;
Key : in std_logic_vector (3 downto 0);
------------ SEG7 -----------------------
HEX0 : out std_logic_vector (7 downto 0);
HEX1 : out std_logic_vector (7 downto 0);
HEX2 : out std_logic_vector (7 downto 0);
HEX3 : out std_logic_vector (7 downto 0);
----------- Received_Signals -------------
TX_Transmitted : in std_logic_vector (175 downto 0)
END COMPONENT;
--Inputs
signal key : std_logic_vector (3 downto 0) := (others => '1');
signal RX_Received : std_logic_vector (255 downto 0);
signal TX_Transmitted : std_logic_vector (175 downto 0);
--Outputs
signal HEX0 : std_logic_vector (7 downto 0);
signal HEX1 : std_logic_vector (7 downto 0);
signal HEX2 : std_logic_vector (7 downto 0);
signal HEX3 : std_logic_vector (7 downto 0);
-- Clock period definitions
constant clock_period : time := 20 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: up_down_counter PORT MAP (
CLK_IN => CLK_IN,
key => key,
RX_Received => RX_Received,
HEX0=> HEX0,
HEX1=> HEX1,
HEX2=> HEX2,
HEX3=> HEX3,
TX_Transmitted => TX_Transmitted
-- Clock process definitions
begin
CLK_IN <= '0';
wait for clock_period/2;
CLK_IN <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
wait for 200 ns;
RX_Received <= (others => '1');
wait for 100 ns;
TX_Transmitted <= (others => '1');
wait for 100 ns;
TX_Transmitted <= (others => '0');
end process;
END; Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
