Danlar81
3 years agoVHDL AND Logic working as OR logic
Hello, I am fairly new to VHDL programming. I purchased a Udemy online course to begin learning along with a cheap Chinese development board which is used in the course, see link below. The dev bo...
ShengN_altera
3 years agoHi,
I had tested the code in one of the device DE1-SOC Cyclone V and seems like the code working fine (check screenshot attached):
11: Led illuminate
10: Led no illuminate
01: Led no illuminate
00: Led no illuminate
May be led of Cyclone IV EP4CE6E22 FPGA a bit different which is active low.
Sheng
- Danlar813 years ago
Thank you for checking the code.
I had to add inverters to all the inputs and outputs to get it to work they way I wanted.
Appreciate you verifying.
