VHDL 2008 unary or operator
I am trying to use the unary or operator.
It compiles and simulates fine in ModelSim, but fails to compile in Quartus with the following error message:
Error (10500): VHDL syntax error at file.vhd(#) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
signal my_flags: boolean_vector(7 downto 0);
if or my_flags then
-- Do something.
end if;I've ensured that the Settings > Compile Settings > VHDL Input > VHDL 2008 is selected.
Any ideas?
- Vicky1
From Error it is indicating that, there might be issue with syntax of entire VHDL code so It is difficult to support with this piece of code, if possible share entire code here or attach with text/word file.
Vicky
- Tim10
Hi Vicky,
Thanks for responding.
Here is an example that compiles in ModelSim, but not in Quartus.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity MyFlags is port ( clock: in std_logic; my_flags: in boolean_vector(7 downto 0) ); end; architecture V1 of MyFlags is constant MY_FLAGS_FALSE: boolean_vector(my_flags'range) := (others => false); begin process(clock) begin if rising_edge(clock) then -- OK: Compiles in Quartus. if not(my_flags = MY_FLAGS_FALSE) then -- Do something. end if; -- OK: Compiles in Quartus. if my_flags /= MY_FLAGS_FALSE then -- Do something. end if; -- OK: Compiles in Quartus. if my_flags = (my_flags'range => false) then -- Do something. end if; -- Not OK: Won't compile in Quartus, but compiles successfully in ModelSim. if or my_flags then -- Do something. end if; -- Not OK: Won't compile in Quartus, but compiles successfully in ModelSim. if or(my_flags) then -- Do something. end if; end if; end process; end;Error messages:
Error (10500): VHDL syntax error at test.vhd(38) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
Error (10500): VHDL syntax error at test.vhd(43) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
Error (10500): VHDL syntax error at test.vhd(43) near text "then"; expecting ":=", or "<="
It's not obvious to me what the problem is. Could you enlighten me?
Tim.
- Vicky1
