VHDL 2008 unary or operator
From Error it is indicating that, there might be issue with syntax of entire VHDL code so It is difficult to support with this piece of code, if possible share entire code here or attach with text/word file.
Vicky
- Tim106 years ago
Hi Vicky,
Thanks for responding.
Here is an example that compiles in ModelSim, but not in Quartus.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity MyFlags is port ( clock: in std_logic; my_flags: in boolean_vector(7 downto 0) ); end; architecture V1 of MyFlags is constant MY_FLAGS_FALSE: boolean_vector(my_flags'range) := (others => false); begin process(clock) begin if rising_edge(clock) then -- OK: Compiles in Quartus. if not(my_flags = MY_FLAGS_FALSE) then -- Do something. end if; -- OK: Compiles in Quartus. if my_flags /= MY_FLAGS_FALSE then -- Do something. end if; -- OK: Compiles in Quartus. if my_flags = (my_flags'range => false) then -- Do something. end if; -- Not OK: Won't compile in Quartus, but compiles successfully in ModelSim. if or my_flags then -- Do something. end if; -- Not OK: Won't compile in Quartus, but compiles successfully in ModelSim. if or(my_flags) then -- Do something. end if; end if; end process; end;Error messages:
Error (10500): VHDL syntax error at test.vhd(38) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
Error (10500): VHDL syntax error at test.vhd(43) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
Error (10500): VHDL syntax error at test.vhd(43) near text "then"; expecting ":=", or "<="
It's not obvious to me what the problem is. Could you enlighten me?
Tim.
- Vicky16 years ago
'or' is a binary logical operator so please follow the proper syntax.
refer the below attachment about operators from Language resource manual & let me know if you have any different issue.
Vicky
- Tim106 years ago
"or" is three things:
- A unary operator (Page 120 of the file you included). Syntax: or my_vector
- A binary operator. Syntax my_vector1 or my_vector2
- A vectorized overloaded logical operator declared in std_logic_1164 (line 145) and defined in std_logic_1164-body (lines 512-522). Syntax: or(my_vector)
Sources:
- https://standards.ieee.org/standard/1076-2008.html
- https://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=4772740 (Pages 28 and 120)
- https://github.com/ghdl/ghdl/blob/master/libraries/ieee2008/std_logic_1164.vhdl
- https://github.com/ghdl/ghdl/blob/master/libraries/ieee2008/std_logic_1164-body.vhdl
- https://www.doulos.com/knowhow/vhdl_designers_guide/vhdl_2008/
ModelSim has no problem compiling the proper syntax. Are there any other options that I need to select in Quartus to enable proper compilation of IEEE Std 1076-2008? How can I verify whether Quartus is using the up-to-date libraries?
EDIT:
I've written a test package to try to figure out what the problem is.
Quartus successfully compiles the package - both the overloaded unary "or" operator and the function or_test, but it won't compile the if statement that uses the overloaded unary "or" operator.
Could there be a problem with my installation of Quartus?
-- library ieee; -- use ieee.std_logic_1164.all; -- use ieee.numeric_std.all; -- use STD.TEXTIO.all; package MyTest is -- OK: Compiles in Quartus. function "or"(r: boolean_vector) return boolean; -- OK: Compiles in Quartus. function or_test(r: boolean_vector) return boolean; end package MyTest; package body MyTest is -- OK: Compiles in Quartus. function "or"(r: boolean_vector) return boolean is constant R_FALSE: boolean_vector(r'range) := (others => false); begin return r /= R_FALSE; end function "or"; -- OK: Compiles in Quartus. function or_test(r: boolean_vector) return boolean is constant R_FALSE: boolean_vector(r'range) := (others => false); begin return r /= R_FALSE; end function or_test; end package body MyTest; library ieee; library work; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.MyTest.all; entity MyFlags is port ( clock: in std_logic; my_flags: in boolean_vector(7 downto 0) ); end; architecture V1 of MyFlags is constant MY_FLAGS_FALSE: boolean_vector(my_flags'range) := (others => false); begin process(clock) begin if rising_edge(clock) then -- OK: Compiles in Quartus. if not(my_flags = MY_FLAGS_FALSE) then -- Do something. end if; -- OK: Compiles in Quartus. if my_flags /= MY_FLAGS_FALSE then -- Do something. end if; -- OK: Compiles in Quartus. if my_flags /= (my_flags'range => false) then -- Do something. end if; Not OK: Won't compile in Quartus, but compiles successfully in ModelSim. if or my_flags then -- Do something. end if; Not OK: Won't compile in Quartus, but compiles successfully in ModelSim. if or(my_flags) then -- Do something. end if; OK: Compiles in Quartus. if work.MyTest.or_test(my_flags) then -- Do something. end if; -- OK: Compiles in Quartus. if work.MyTest."or"(my_flags) then -- Do something. end if; -- Not OK: Won't* compile in Quartus, but compiles successfully in ModelSim. -- * If the MyTest package is commented out, Quartus gives Error (10511): VHDL Qualified Expression error at test.vhd(#): "or" type specified in Qualified Expression must match boolean type that is implied for expression by context -- * If the MyTest package is compiled, Quartus successfully compiles using work.MyTest."or"() -- See NOTE 3 on page 28 of IEEE Std 1076-2008 if "or"(my_flags) then -- Do something. end if; end if; end process; end;BTW, a new standard was published recently, IEEE Std 1076-2019: https://standards.ieee.org/standard/1076-2019.html
- Vicky16 years ago
Thanks for the patience & details.
Are there any other options that I need to select in Quartus to enable proper compilation of IEEE Std 1076-2008?--- -- -- Intel Quartus Pro edition has full support for VHDL-2008, Intel Quartus Standard has limited support, please refer the Page-7 from link below & check your Quartus edition.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/br/br-quartus-prime-software.pdf
Vicky
