10 years agoVery long compilation time
Hi, I am having a problem with extremely long compilation time. A simple VHDL code is taking 1 hour to compile. I am using Quartus 15.1 Standard Edition (trial version). I have seen that in the ...
10 years ago --- Quote Start --- So finally I solved this problem by disabling the parallel compilation in Quartus II. I went to Assignments-->settings --> Compilation process settings --> Maximum processors allowed = 1 Also, I disabled Modelsim by going to EDA tool settings--> Simulation --> None. My VHDL code was able to compile in just 4 minutes. Hopefully it will be useful for other people. --- Quote End --- REALY great thanks.i stuck at physical optimization for 4 hours until I gave up .Also made me think that project i made was wrong in some place.But when i ran it in friend's comp it took about 1 min on fitter ....then i found your post .I wish i could find it faster :)
