10 years agoVery long compilation time
Hi, I am having a problem with extremely long compilation time. A simple VHDL code is taking 1 hour to compile. I am using Quartus 15.1 Standard Edition (trial version). I have seen that in the ...
10 years ago --- Quote Start --- hi, kind of surprise to heat this as now a days computer come with powerful systems, did you installed some resource consuming antivirus or real time threat scanner running at the background? --- Quote End --- Hi, Yes, I have anti virus and windows backup software running in the background but I tried disabling them as well later on and still the result was that with 2 processors it took 1-2 hrs depending on how complex code I was compiling. When, I switched to just one processor( i.e. disabled the parallel compilation), specially the fitting process went very fast. This was amazing considering the fact that parallel compilation should speed up the process. Anyway, I am currently sticking to a way that works faster for me.:)
