10 years agoVery long compilation time
Hi, I am having a problem with extremely long compilation time. A simple VHDL code is taking 1 hour to compile. I am using Quartus 15.1 Standard Edition (trial version). I have seen that in the ...
10 years ago --- Quote Start --- oh ) nice Misha.kumar ... The quartus contain many small files even i mark all as trusted software for antivirus. <- degraded perfomance with factor up to 2. then virual memory used at fitter stage is quite big. <- is it enough , so you don't enlarge disk swap. Accelarated launch and prioity changing on the fly with so called "Live optimizaton" software <- it creates troubles with quartus2 I wonder the time per stage in report file and actual real time -> for example 15 sec in report and 4 minutes in realtime. --- Quote End --- excellent analysis !
