15 years ago
Verilog XOR issue
Hi All,
I have a working piece of code :
if(in_I & in_Q) cnt <= cnt + `INC_SIZ;
if(in_I & !in_Q) cnt <= cnt - `INC_SIZ;
if(!in_I & in_Q) cnt <= cnt - `INC_SIZ;
if(!in_I & !in_Q) cnt <= cnt + `INC_SIZ;
in an attempt to be clever, I changed it to
if(in_I ^ in_Q) begin cnt <= cnt + `INC_SIZ; end
else begin cnt <= cnt - `INC_SIZ; end
which stopped working.
in_I and in_Q are single bit input ports.
What am I doing that is daft, the logic looks OK to me.
Mark
    I don't know. I use a similar construct with ^ operator and it works.
    Did you try if(in_I != in_Q) ? It should be the same.
    I'm assuming all this is in a always@(posedge clk) block. Is this correct?
    Or maybe is always@(in_I or in_Q) ?
    Just a remark: I'm rather concerned about the first piece of code (working).
    I'd have written it: if... else if...else if... else
    Your first logic is equivalent to this below:
    if(in_I ^ in_Q) begin cnt <= cnt - `INC_SIZ; end
    else begin cnt <= cnt + `INC_SIZ; end
    Hi guys,
    Thanks for your thoughts.
    I tried changing xor to == and != without success.
    Here are the full modules.
    All I am doing is building an up/down counter based on inputs from an I/Q rotary shaft encoder. I and Q do not change together.
    There are two cascaded meta stability D latched between this module and the hardware.
    I am not worried about direction of count and the final output assignments are just sample probes at the moment.
    One module works, the other does not.
    Compilation size is also different - I was expecting them to compile to same code.
    Mark
    ========= works
    // IQ counter
    module IQ_ctr(in_I, in_Q, clk, out_0, out_1);
    `define INC_SIZ 16'd125
    //----------Output Ports--------------
    output out_0;
    output out_1;
    //------------Input Ports--------------
    input in_I, in_Q, clk;
    //------------Internal Variables--------
    reg out_0;
    reg out_1;
    reg [16:0] cnt;
    reg last_I;
    reg last_Q;
    //-------------Code Starts Here-------
    always @(posedge clk)
    begin
    if(in_I ^ last_I) // I changed
    begin
    end
    if(in_Q ^ last_Q) // Q changed
    begin
    if(in_Q & in_I) cnt <= cnt - `INC_SIZ;
    if(in_Q & !in_I) cnt <= cnt + `INC_SIZ;
    if(!in_Q & in_I) cnt <= cnt + `INC_SIZ;
    if(!in_Q & !in_I) cnt <= cnt - `INC_SIZ;
    end
    last_I <= in_I;
    last_Q <= in_Q;
    out_0 = cnt[15];
    out_1 = cnt[14];
    end
    endmodule
    ========= does not work
    // IQ counter
    output out_0;
    output out_1;
    reg out_0;
    reg out_1;
    reg [16:0] cnt;
    reg last_I;
    reg last_Q;
    begin
    begin
    if(in_I != in_Q) cnt <= cnt - `INC_SIZ;
    else cnt <= cnt + `INC_SIZ;
    end
    begin
    if(in_I != in_Q) cnt <= cnt + `INC_SIZ;
    else cnt <= cnt - `INC_SIZ;
    end
    last_I <= in_I;
    last_Q <= in_Q;
    out_0 = cnt[15];
    out_1 = cnt[14];
    end
    endmodule
    Arrgh, busted hardware !
    That was quite a waste of a few hours.
    The problem really smelt like a compiler bug.
    Change to new hardware and everything looks OK.
    Mark
