15 years ago
verilog simulation model issue of altpll in Straitx IV device
Does anybody meet this case as below?
I'm using Stratix IV for one project and I use the on chip PLL of device to generate high clock for our system. I simulate my design with Cadence ncverilog tool. When I run the simulation to FPGA version code ( a lot of altera memories and PLL model ), the simulation is very slow. While I run the ASIC version simulation, it's quick. I tried to disable the PLL verilog model and use a simple one, and it's fast now.
Is there any option we need to configure when we use PLL verilog simulation model?
    I hear about users writing their own PLL simulation models quite a bit(I don't have one handy to post though). Bottom line is that it has a lot of activity to mimic how a PLL works, when most users want the simplest/quickest model possible. Hopefully Altera does some improvements on this(both in PLL and transceivers) where the user can select from multiple simulation models depending on their sim goals, but I believe what you're doing is a good solution used by many.
    I have the same issue. What is this asic version of pll simulation model.
    Can some expert point me to a lightweight simulation model for the PLL.
    I can write my own clock generator but it is not the same as verifying with
    a programmable PLL sim. model
    Thanks!
