16 years ago
Verilog sequential code
I have a shift register made with DFF flip flops.
When using the command "create HDL file for current files" the DFF are synthesized using blocking assignments as:
always -at-(posedge CK or negedge R)
begin
if (!R)
begin
D1 = 0;
end
else
begin
D1 = D0;
end
end
This seems to be dangerous and actually produces random behaviour during RTL simulation.
Is this a bug or there's something to set in order to get proper Verilog code starting from bdf files?
Thanks in advance.
    Unfortunately it is not.
    The correct way to define a FF is:
    begin
    if (!R)
    begin
    D1 <= 0;
    end
    else
    begin
    D1 <= D0;
    end
    end
    Using blockng assignment (= instead of <=), when using multiple FF as in a shift register, results in random behavior and race conditions.
    hello .
    am running verilog code and the same error keep showing up ,
    errors :
    Error (10028): Can't resolve multiple constant drivers for net "hazard" at design1.v(159)
    Error (10029): Constant driver at design1.v(138)
    Error (10028): Can't resolve multiple constant drivers for net "sample" at design1.v(159)
    Error: Can't elaborate top-level user hierarchy
    Error: Quartus II Analysis & Synthesis was unsuccessful. 4 errors, 5 warnings
    Error: Peak virtual memory: 181 megabytes
    Error: Processing ended: Tue Apr 20 13:20:20 2010
    Error: Elapsed time: 00:00:02
    Error: Total CPU time (on all processors): 00:00:01
    Error: Quartus II Full Compilation was unsuccessful. 6 errors, 5 warnings http://www.alteraforum.com/forum//pr...c/progress.gif (http://www.alteraforum.com/forum//proweb/misc/progress.gif)
    this is the code ;
    module design1 (
    clock ,
    reset ,
    hazard ,
    pulse
    ); // End of port list
    //-------------Input Ports-----------------------------
    input clock ;
    input reset ;
    input pulse ;
    //-------------Output Ports----------------------------
    output hazard ;
    //-------------Input ports Data Type-------------------
    // By rule all the input ports should be wires
    wire clock ;
    wire reset ;
    //-------------Output Ports Data Type------------------
    // Output port can be a storage element (reg) or a wire
    reg [15:0] pulse_cntr;
    reg pulse_reset;
    reg [15:0] period_cntr;
    reg [15:0] sample_value;
    reg sample;
    reg [23:0] result, result_ns;
    reg [23:0] vt;
    reg hazard;
    initial begin
    hazard = 1'b0 ;
    end
    always @ ( sample_value ) begin
    result_ns = sample_value * 4'hc;
    case ( result )
    24'h00006c: vt = 24'hcccccc;
    24'h0186A0: vt = 24'h007530;
    24'h030D40: vt = 24'h00EA60;
    24'h0493E0: vt = 24'h01ADB0;
    24'h061A80: vt = 24'h020F58;
    24'h07A120: vt = 24'h029810;
    24'h0927C0: vt = 24'h030D20;
    24'h0AAE60: vt = 24'h038270;
    24'h0C3500: vt = 24'h041EB0;
    24'h0DBBA0: vt = 24'h04BAF0;
    24'h0F4240: vt = 24'h053020;
    24'h10C8E0: vt = 24'h05CC60;
    24'h124F80: vt = 24'h064190;
    24'h13D620: vt = 24'h0704E0;
    24'h155CC0: vt = 24'h077A10;
    24'h16E360: vt = 24'h07EF40;
    24'h186A00: vt = 24'h086470;
    24'h19F0A0: vt = 24'h0927C0;
    24'h1B7740: vt = 24'h099CF0;
    24'h1CFDE0: vt = 24'h0A6040;
    24'h1E8480: vt = 24'h0AFC80;
    24'h200B20: vt = 24'h0B4AA0;
    24'h2191C0: vt = 24'h0C0DF0;
    24'h231860: vt = 24'h0CAA30;
    24'h249F00: vt = 24'h0D1F60;
    24'h2625A0: vt = 24'h0DE2B0;
    24'h27AC40: vt = 24'h0EF7E0;
    24'h2932E0: vt = 24'h0EF420;
    24'h2AB980: vt = 24'h0F9060;
    24'h2C4020: vt = 24'h102CA0;
    24'h2DC6C0: vt = 24'h10EFF0;
    24'h2F4D60: vt = 24'h116F20;
    24'h30D400: vt = 24'h120160;
    24'h325AA0: vt = 24'h12C4B0;
    24'h33E140: vt = 24'h1360F0;
    24'h3567E0: vt = 24'h13D620;
    24'h36EE80: vt = 24'h149970;
    24'h387520: vt = 24'h1535B0;
    24'h39FBC0: vt = 24'h15D1F0;
    24'h3B8260: vt = 24'h169540;
    24'h3D0900: vt = 24'h1731A0;
    24'h3E8F9F: vt = 24'h17A6B0;
    24'h401640: vt = 24'h1842F0;
    24'h419CE0: vt = 24'h190640;
    24'h43237F: vt = 24'h19A280;
    24'h44AA20: vt = 24'h1A65D0;
    24'h4630C0: vt = 24'h1ADB00;
    24'h47B760: vt = 24'h1B7740;
    24'h493E00: vt = 24'h1C3A90;
    24'h4AC4A0: vt = 24'h1CD6D0;
    24'h4C4B40: vt = 24'h1D7310;
    24'h4DD1E0: vt = 24'h1E3660;
    24'h4F5880: vt = 24'h1ED2A0;
    24'h50DF20: vt = 24'h1F95EF;
    24'h5265C0: vt = 24'h203230;
    24'h53EC60: vt = 24'h20A760;
    24'h557300: vt = 24'h2191C0;
    24'h56F9A0: vt = 24'h222E00;
    24'h588040: vt = 24'h22F150;
    24'h5A06E0: vt = 24'h238D90;
    24'h5B8D80: vt = 24'h2450E0;
    24'h5D1420: vt = 24'h243610;
    24'h5E9AC0: vt = 24'h258960;
    24'h602160: vt = 24'h264CB0;
    24'h61A800: vt = 24'h271000;
    24'h632EA0: vt = 24'h27AC40;
    24'h64B540: vt = 24'h282170;
    24'h663BE0: vt = 24'h290BD0;
    24'h67C280: vt = 24'h29CF20;
    24'h694920: vt = 24'h2A6B60;
    24'h6ACFC0: vt = 24'h2B07A0;
    24'h6C5660: vt = 24'h2BCAF0;
    24'h6DDD00: vt = 24'h2CB550;
    24'h6F63A0: vt = 24'h2D5190;
    24'h70EA40: vt = 24'h2F4D60;
    24'h7270E0: vt = 24'h2EB120;
    24'h73F780: vt = 24'h2F7470;
    24'h757E20: vt = 24'h2FE9A0;
    24'h7704C0: vt = 24'h30ACF0;
    24'h788B60: vt = 24'h317040;
    24'h7A1200: vt = 24'h320C80;
    default : vt = 24'h0000;
    endcase
    if ( result_ns <= vt )
    hazard = 1;
    else
    hazard = 0;
    end
    // Pulse Counter
    always @(posedge pulse or posedge reset) begin
    if ( reset == 1'b1 ) begin
    sample_value <= 0;
    pulse_cntr <=0;
    hazard = 0 ;
    end
    else if (sample == 1)
    begin
    sample_value <= pulse_cntr+1;
    pulse_cntr <= 0;
    sample <= 0;
    end
    else
    begin
    pulse_cntr <= pulse_cntr + 1;
    end
    end
    // Period counter
    always @(posedge clock or posedge reset) begin
    if (reset == 1'b1)
    begin
    period_cntr <= 0;
    sample <= 0;
    hazard = 0 ;
    end
    else if ( period_cntr == 16'h000f)//557300
    begin
    period_cntr <= 16'h0000;
    sample <= 1;
    end
    else
    begin
    period_cntr <= period_cntr + 1;
    end
    end
    if (reset == 1'b1)// begin
    result <= 0;
    else
    result <= result_ns ;
    end
    endmodule // End of Module design
    1)
    initial begin
    hazard = 1'b0 ;
    end
    You cannot use initial for designing a circuit.
    It is only useful for testbench.
    2)
    begin
    pulse_cntr <= 0;
    sample <= 0;
    This circuit wants to put sample at 0 when sample is 1? Which circuit can do this?
    For Beginner:
    I think you are using HDL as if you were programming in C or other similar languages.
    Actually in Verilog every 'always' block executes indipendently whenever the specified condition is true.
    So you are making multiple assignments to the same signal/register; besides, your code won't work as you expect.
    Still no reply.
    I'll try to see if this has been corrected in the new 10.0 release of the QuartusII software
    --- Quote Start ---
    Still no reply.
    --- Quote End ---
    your problem is that you try to set some reg ( hazard, sample ) in different processes.
    You have to put them together in one.
    module design1 (
    clock ,
    reset ,
    hazard ,
    pulse
    input clock ;
    input reset ;
    input pulse ;
    output hazard ;
    wire clock ;
    wire reset ;
    reg pulse_reset;
    reg sample;
    reg [23:0] vt;
    reg hazard;
    initial begin
    hazard = 1'b0 ;
    end
    case ( result )
    endcase
    hazard = 1;
    else
    hazard = 0;
    end
    // Pulse Counter
    sample_value <= 0;
    pulse_cntr <=0;
    hazard = 0 ;end
    begin
    pulse_cntr <= 0;
    sample <= 0;
    end
    else
    begin
    end
    end
    // Period counter
    if (reset == 1'b1)
    begin
    period_cntr <= 0;
    sample <= 0;
    hazard = 0 ;end
    begin
    sample <= 1;
    end
    else
    begin
    end
    end
    result <= 0;
    else
    end
    Kind regards
    GPK
    --- Quote Start ---
    module design1 (
    clock ,
    reset ,
    hazard ,
    pulse
    input clock ;
    input reset ;
    input pulse ;
    output hazard ;
    wire clock ;
    wire reset ;
    reg pulse_reset;
    reg sample;
    reg [23:0] vt;
    reg hazard;
    initial begin
    hazard = 1'b0 ;
    end
    case ( result )
    endcase
    hazard = 1;
    else
    hazard = 0;
    end
    // Pulse Counter
    sample_value <= 0;
    pulse_cntr <=0;
    hazard = 0 ;end
    begin
    pulse_cntr <= 0;
    sample <= 0;
    end
    else
    begin
    end
    end
    // Period counter
    if (reset == 1'b1)
    begin
    period_cntr <= 0;
    sample <= 0;
    hazard = 0 ;end
    begin
    sample <= 1;
    end
    else
    begin
    end
    end
    result <= 0;
    else
    end
    Kind regards
    GPK
    --- Quote End ---
    Thanks Pletz but my comment of no replies refers to the original thread question.
    The problem with the code is an off topic addition.
    The original problem was that QuartusII Create HDL command uses blcking assignment to describe Flip flops. This causes simulation errating behaviour.
