--- Quote Start ---
your problem is that you try to set some reg ( hazard, sample ) in different processes.
You have to put them together in one.
module design1 (
clock ,
reset ,
hazard ,
pulse
); // End of port list
//-------------Input Ports-----------------------------
input clock ;
input reset ;
input pulse ;
//-------------Output Ports----------------------------
output hazard ;
//-------------Input ports Data Type-------------------
// By rule all the input ports should be wires
wire clock ;
wire reset ;
//-------------Output Ports Data Type------------------
// Output port can be a storage element (reg) or a wire
reg [15:0] pulse_cntr;
reg pulse_reset;
reg [15:0] period_cntr;
reg [15:0] sample_value;
reg sample;
reg [23:0] result, result_ns;
reg [23:0] vt;
reg hazard;
initial begin
hazard = 1'b0 ;
end
always @ ( sample_value ) begin
result_ns = sample_value * 4'hc;
case ( result )
24'h00006c: vt = 24'hcccccc;
24'h7A1200: vt = 24'h320C80;
default : vt = 24'h0000;
endcase
if ( result_ns <= vt )
hazard = 1;
else
hazard = 0;
end
// Pulse Counter
always @(posedge pulse or posedge reset) begin
if ( reset == 1'b1 ) begin
sample_value <= 0;
pulse_cntr <=0;
hazard = 0 ;end
else if (sample == 1)
begin
sample_value <= pulse_cntr+1;
pulse_cntr <= 0;
sample <= 0;
end
else
begin
pulse_cntr <= pulse_cntr + 1;
end
end
// Period counter
always @(posedge clock or posedge reset) begin
if (reset == 1'b1)
begin
period_cntr <= 0;
sample <= 0;
hazard = 0 ;end
else if ( period_cntr == 16'h000f)//557300
begin
period_cntr <= 16'h0000;
sample <= 1;
end
else
begin
period_cntr <= period_cntr + 1;
end
end
if (reset == 1'b1)// begin
result <= 0;
else
result <= result_ns ;
end
endmodule // End of Module design
Kind regards
GPK
--- Quote End ---
Thanks Pletz but my comment of no replies refers to the original thread question.
The problem with the code is an off topic addition.
The original problem was that QuartusII Create HDL command uses blcking assignment to describe Flip flops. This causes simulation errating behaviour.
