14 years agoIs the output dependent on something that might not be initialized like a flip flop or RAM in module B?
Also I would double check signal widths in both modules to make sure signals are not getting truncated somewhere in your logic. I'm not sure if there is a way to check for this in Modelsim but the Quartus II synthesis engine should issue you a warning when this happens.
