15 years agoVerilog issue with case & assign statement
I defined an assign and case statement in my code as following: // NOT into a process assign cf_data = cf_we_n ? cf_data_in : cf_data_out; ... // State into a case statement, into a process. CM_WR_DATA: begin cf_we_n = 1'b0; i_wr = i_wr + 1; n_pin_control = CM_WR_WAIT; end It seems pretty short and easy, but I got an issue : my state CM_WR_DATA is done two times instead of one time, so my integer i_wr is incremented by 2. It is due to the assign statement. In fact, if I comment the assign statement, it works. By the same way, if I comment the cf_we_n, it works too. cf_data is not in the sensitive list of the process involved. I have only one state machine, so there isn't any conflicts. So I tried to create a case state in addition: CM_WR_DATA: begin cf_we_n = 1'b0; n_pin_control = CM_WR_ADDITIONNAL; end CM_WR_ADDITIONNAL: begin i_wr = i_wr + 1; n_pin_control = CM_WR_WAIT; end It doesn't fix my problem, i_wr is still incremented by 2. Does sb have any ideas ? Thanks !
