15 years ago
Verilog design and RTL viewer (Quartus II 8.1)
Hi everyboy,
I am not used with verilog (telling the truth I'm not used in design in general :P ) and I have a question... I don't understand why some register i shown on the right and only one on the left in this simple counter
module counter (data, count, rco, load, enable, reset, clock);
parameter WIDTH=4;
input  data;
input load, enable, reset, clock;
output  count;
output rco;
wire  data;
wire rco, load, enable, reset, clock;
reg  count;
assign rco = count == {WIDTH{1'b1}} ? 1'b1 : 1'b0;
always @ (posedge clock)
	begin
		if (!reset)
			count <= 0;
		else if (enable) begin
				if (load) count <= data;
				else count <= count + 1'b1;
			 end
	end
endmodule
There is a screenshot of RTL viewer.
img840.imageshack.us/img840/196/countera.jpg
(sorry i cant post as image ... forumm need 5 post :( )
Is there a problem? Some options are wrong? I use Quartus 8.1 because i like the integreted simulator, from version 9 there isn't right?
Thanks a lot in advance,
Alessandro Vincenzi
    The block placement in RTL and gate level netlists is arbitrary and doesn't have a particular meaning. Everything looks correct in your design.
    that's all because the damn synthesizer modifies your code and creates different circuit.new circuit will have same functionality. but it makes much harder to track down which variable became which element in RTL.
