8 years agoVerilog Coding
I'm getting the following error when I'm implementing the below Verilog code. [Synth 8-403] loop limit (65536) exceeded parameter N=10; parameter M=8; parameter depth=(1<<N); reg [M-1:0]stack_mem[depth-1:0]; always@(posedge clk) begin if (rst==1'b1) begin next_sp=0; dataout=0; for(i=0;i<(depth-1);i=i+1) begin stack_mem[i]=0; end end end Here "For loop" has to increase only up to 1023 but again why I'm getting loop limit exceeded error? Can anyone help me out? Thanks in advance.2 Replies
Where is i declared? Probably should be declared as an integer;
Probably like this, with the added text in red:
Note that by requiring that clearing the whole memory in one clock cycle be done, you will be forcing the implementation of stack_mem[] to be done be an array of clearable registers, and not using a block_ram type of memory structure. Hope that is what you intend. Also clk, rst, next_sp, and dataout need to be declared somewhere (maybe you left out some code ... ?)always@(posedge clk) begin : block_name integer i; if (rst==1'b1) begin next_sp=0; dataout=0; for(i=0;i<(depth-1);i=i+1) begin stack_mem=0; end end end - Altera_Forum
Thanks for your response. It's my mistake.i declared "i" as a single bit.
