8 years agoVerilog Coding
Hello, I'm getting the following error when I'm implementing the below Verilog code. [Synth 8-403] loop limit (65536) exceeded parameter N=10; parameter M=8; parameter depth=(1<<N...
8 years agoWhere is i declared? Probably should be declared as an integer;
Probably like this, with the added text in red:always@(posedge clk)
begin : block_name
integer i;
if (rst==1'b1)
begin
next_sp=0;
dataout=0;
for(i=0;i<(depth-1);i=i+1)
begin
stack_mem=0;
end
end
end Note that by requiring that clearing the whole memory in one clock cycle be done, you will be forcing the implementation of stack_mem[] to be done be an array of clearable registers, and not using a block_ram type of memory structure. Hope that is what you intend. Also clk, rst, next_sp, and dataout need to be declared somewhere (maybe you left out some code ... ?)
