14 years ago
vector eaveform file quartus
Hi all, I've a big problem with quartus to view vector waveform file specialy in quartus version 9, 10, 11.
I create a simple shematic file in quartuse v8, and want to see the wave, but unfortunately, when i play start simulation, i dont have any error but i cant see the result. of course i see warning about in license,
by the way, i install the v10,11 of quartuse, how can create waveform in them?!
    There is no simulator in Quartus 9.1+ you have to use modelsim instead.
    Thanks alot, I install quartus 10, i create new shematic and do start simulation. and add modelsim6.1 in tools menu- options and add it again in assignments menu- settings. after that click processing menu- start analyses and elaboration and the end, tools meenu- eda simulation tools- eda rtl simulation, but unfortunetly i see this error,
    ...check nativelog file ...
    this file is containts
    Info: Start Nativelink Simulation process
    Error: NativeLink did not detect any HDL files in the project
    Error: NativeLink simulation flow was NOT successful
    ================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
    Nativelink TCL script failed with errorCode: NONE
    Nativelink TCL script failed with errorInfo: NativeLink did not detect any HDL files in the project
    invoked from within
    "if ![qmap_successfully_completed] {
    nl_postmsg error "Error: Run Analysis and Elaboration successfully before starting RTL NativeLink Simulation"..."
    (procedure "run_eda_simulation_tool" line 170)
    invoked from within
    "run_eda_simulation_tool eda_opts_hash"
    so thanks....
