14 years agoThanks alot, I install quartus 10, i create new shematic and do start simulation. and add modelsim6.1 in tools menu- options and add it again in assignments menu- settings. after that click processing menu- start analyses and elaboration and the end, tools meenu- eda simulation tools- eda rtl simulation, but unfortunetly i see this error,
...check nativelog file ... this file is containts Info: Start Nativelink Simulation process Error: NativeLink did not detect any HDL files in the project Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: NONE Nativelink TCL script failed with errorInfo: NativeLink did not detect any HDL files in the project invoked from within "if ![qmap_successfully_completed] { nl_postmsg error "Error: Run Analysis and Elaboration successfully before starting RTL NativeLink Simulation"..." (procedure "run_eda_simulation_tool" line 170) invoked from within "run_eda_simulation_tool eda_opts_hash" so thanks....
