1 Reply
I'm not familiar with any specific scripts to set up the Altera libraries in VCS. However, I did find a useful design example on the Altera website:
http://www.altera.com/support/examples/vcs/exm-vcs-timing-verilog.html Based on the TCL script that was provided, here's a snit it of the TCL file to setup your simulation: vcs # -R # ## To invoke the GUI, use -RI option -RI # ## 64-bit version # -full64 # ## record all the messages in a log file named test_net.log -l test_net.log # ## inlcude the path for libraries required for simulation -v stratixii_atoms.v # ## compile the test bench test_multiplier.v # ## inlcude the design files multiplier.vo # ## include these switches for transporting path delays and internal delays # ## to get more information on these switches, refer to VCS Userguide +transport_int_delays +pulse_int_e/0 +pulse_int_r/0 +transport_path_delays +pulse_e/0 +pulse_r/0 If you refer to the "include the path for libraries required for simulation", here's the command for adding the Stratix II device library for VCS simulation: >> -v stratixii_atoms.v Not sure if this helps, but just my two cents. -Pld_wiz
