uvm_config_db fails to get interface UVM QuestaSim
Hi there
I am trying to get a simulation working in QuestaSim - Intel FPGA Edition using UVM.
Below is the design with all the UVM class extensions
`timescale 1ns/1ps `include "uvm_macros.svh" `define LENGTH 4 import uvm_pkg::*; class Item extends uvm_sequence_item; `uvm_object_utils(Item) rand bit in; bit out; virtual function string convert2str(); return $sformatf("in=%0d, out=%0d", in, out); endfunction function new(string name = "Item"); super.new(name); endfunction constraint c1 {in dist {0:/20, 1:/80}; } endclass class gen_item_seq extends uvm_sequence; `uvm_object_utils(gen_item_seq) function new(string name="gen_item_seq"); super.new(name); endfunction rand int num; // config total number of items to be sent constraint c1 { soft num inside {[10:50]}; } virtual task body (); for(int i = 0; i < num; i++) begin Item m_item = Item::type_id::create("m_item"); start_item(m_item); m_item.randomize(); `uvm_info("SEQ", $sformatf("Generate new item: %s", m_item.convert2str()), UVM_HIGH) finish_item(m_item); end `uvm_info("SEQ", $sformatf("Done generation of %0d items", num), UVM_LOW) endtask endclass //The driver is responsible for driving transactions to the DUT // All it does it to get a transaction from the mailbox if it is // available and drive it out into the DUT interface class driver extends uvm_driver #(Item); `uvm_component_utils(driver) function new(string name = "driver", uvm_component parent=null); super.new(name, parent); endfunction virtual des_if vif; virtual function void build_phase(uvm_phase phase); super.build_phase(phase); if(!uvm_config_db#(virtual des_if)::get(this, "", "des_if", vif)) `uvm_fatal("DRV", "Could not get vif") endfunction virtual task run_phase(uvm_phase phase); super.run_phase(phase); forever begin Item m_item; `uvm_info("DRV", $sformatf("Wait for item from sequencer"), UVM_HIGH) seq_item_port.get_next_item(m_item); drive_item(m_item); seq_item_port.item_done(); end endtask virtual task drive_item(Item m_item); @(vif.cb); vif.cb.in <= m_item.in; endtask endclass // The monitor has a virtual interface handl with which // it can monitor the events happening on the interface // It sees new transcations then captures information // into a packet and sends it to the scoreboard // using another mailbox class monitor extends uvm_monitor; `uvm_component_utils(monitor) function new(string name="monitor", uvm_component parent=null); super.new(name, parent); endfunction uvm_analysis_port #(Item) mon_analysis_port; virtual des_if vif; virtual function void build_phase(uvm_phase phase); super.build_phase(phase); if(!uvm_config_db#(virtual des_if)::get(this, "", "des_vif", vif)) `uvm_fatal("MON", "Could not get vif") mon_analysis_port = new ("mon_analysis_port", this); endfunction virtual task run_phase(uvm_phase phase); super.run_phase(phase); //This task monitors the interface for a complete // transaction and writes into analysis port when complete forever begin @(vif.cb); if(vif.rstn) begin Item item = Item::type_id::create("item"); item.in = vif.in; item.out = vif.cb.out; mon_analysis_port.write(item); `uvm_info("MON", $sformatf("Saw item %s", item.convert2str()), UVM_HIGH) end end endtask endclass // The scoreboard is reponsible for checking design functionality and // should track input and try to match the pattern and ensure that // the design has found the pattern as well. The scoreboard should // flag an error if the design didn't find the pattern and ensure // that "out" remains zero, and if the design found the pattern, // "out" is set to the correct value class scoreboard extends uvm_scoreboard; `uvm_component_utils(scoreboard) function new(string name="scoreboard", uvm_component parent=null); super.new(name, parent); endfunction bit [`LENGTH-1:0] ref_pattern; bit [`LENGTH-1:0] act_pattern; bit exp_out; uvm_analysis_imp #(Item, scoreboard) m_analysis_imp; virtual function void build_phase(uvm_phase phase); super.build_phase(phase); m_analysis_imp = new("m_analysis_imp", this); if(!uvm_config_db#(bit[`LENGTH-1:0])::get(this, "*", "ref_pattern", ref_pattern)) `uvm_fatal("SCBD", "Did not get ref_pattern !") endfunction virtual function write(Item item); act_pattern = act_pattern << 1 | item.in; `uvm_info("SCBD", $sformatf("in=%0d out=%0d ref=0b%0b act=0b%0b", item.in, item.out, ref_pattern, act_pattern), UVM_LOW) // Always check that expected out value is the actual obseved value, // Since it takes 1 clock for out to be updated after pattn match, //do the check first then update exp_out value if(item.out != exp_out) begin `uvm_error("SCBD", $sformatf("ERROR ! out=%0d exp=%0d", item.out, exp_out)) end else begin `uvm_info("SCBD", $sformatf("Pass ! out=%0d exp=%0d", item.out, exp_out), UVM_HIGH) end // If current index has reached the full pattern, then set exp_out to be 1 // which will be checked in the next clock. If pattern is not complete, keep // exp_out to zero if(!(ref_pattern ^ act_pattern)) begin `uvm_info("SCBD", $sformatf("Pattern found to match, next one should be 1!"), UVM_LOW) exp_out = 1; end else begin exp_out = 0; end endfunction endclass // Create an intermediate container called "agent" to hold // driver, monitor and sequencer class agent extends uvm_agent; `uvm_component_utils(agent) function new(string name="agent", uvm_component parent=null); super.new(name, parent); endfunction driver d0; //Driver handle monitor m0; //Monitor handle uvm_sequencer #(Item) s0; //Sequence Handle virtual function void build_phase(uvm_phase phase); super.build_phase(phase); s0 = uvm_sequencer#(Item)::type_id::create("s0", this); d0 = driver::type_id::create("d0", this); m0 = monitor::type_id::create("m0", this); endfunction virtual function void connect_phase(uvm_phase phase); super.connect_phase(phase); d0.seq_item_port.connect(s0.seq_item_export); endfunction endclass // The environment is a contain objet simply to hold // all verification components together. This environment can // then be reused later and all components in it would be // automatically connected and available for use class env extends uvm_env; `uvm_component_utils(env); function new(string name="env", uvm_component parent=null); super.new(name, parent); endfunction agent a0; //agent handle scoreboard sb0; //scoreboard handle virtual function void build_phase(uvm_phase phase); super.build_phase(phase); a0 = agent::type_id::create("a0", this); sb0 = scoreboard::type_id::create("sb0", this); endfunction virtual function void connect_phase(uvm_phase phase); super.connect_phase(phase); a0.m0.mon_analysis_port.connect(sb0.m_analysis_imp); endfunction endclass // Test class instantiates the environment and starts it. class base_test extends uvm_test; `uvm_component_utils(base_test) function new(string name="base_test", uvm_component parent=null); super.new(name, parent); endfunction env e0; bit[`LENGTH-1:0] pattern = 4'b1011; gen_item_seq seq; virtual des_if vif; virtual function void build_phase(uvm_phase phase); super.build_phase(phase); // create the environment e0 = env::type_id::create("e0", this); // Get virtual IF handle from the top level and pass it to everything // in the env level if(!uvm_config_db#(virtual des_if)::get(this, "", "des_if", vif)) `uvm_fatal("TEST", "Did not get vif") uvm_config_db#(virtual des_if)::set(this, "e0.a0.*", "des_if", vif); // Setp pattern queue and place into config db uvm_config_db#(bit[`LENGTH-1:0])::set(this, "*", "ref_pattern", pattern); // Create sequence and randomise it seq = gen_item_seq::type_id::create("seq"); seq.randomize(); endfunction virtual task run_phase(uvm_phase phase); phase.raise_objection(this); apply_reset(); seq.start(e0.a0.s0); #200; phase.drop_objection(this); endtask virtual task apply_reset(); vif.rstn <= 0; vif.in <= 0; repeat(5) @ (posedge vif.clk); vif.rstn <= 1; repeat(10) @ (posedge vif.clk); endtask endclass class test_1011 extends base_test; `uvm_component_utils(test_1011) function new (string name="test_1011", uvm_component parent=null); super.new(name, parent); endfunction virtual function void build_phase(uvm_phase phase); pattern = 4'b1011; super.build_phase(phase); seq.randomize() with { num inside {[300:500]}; }; endfunction endclass // This interface allows verification components to access DUT signals // using a virtual interface handle interface des_if (input bit clk); logic rstn; logic in; logic out; clocking cb @ (posedge clk); default input #1step output #3ns; input out; output in; endclocking endinterface module tb(); reg clk; always #10 clk =~ clk; des_if _if(clk); det_1011 u0 ( .clk(clk), .rstn(_if.rstn), .in(_if.in), .out(_if.out) ); initial begin clk <= 0; uvm_config_db#(virtual des_if)::set(null, "uvm_test_top", "des_vif", _if); run_test("test_1011"); end endmodule : tb // Design v1.0 module det_1011 (input clk, input rstn, input in, input out); parameter IDLE = 0, S1 = 1, S10 = 2, S101 = 3, S1011 = 4; reg [2:0] cur_state, next_state; assign out = cur_state == S1011 ? 1 : 0; always @ (posedge clk) begin if(!rstn) cur_state <= IDLE; else cur_state <= next_state; end always @ (cur_state or in) begin case(cur_state) IDLE: begin if (in) next_state = S1; else next_state = IDLE; end S1 : begin if (in) next_state = IDLE; else next_state = S10; end S10 : begin if (in) next_state = S101; else next_state = IDLE; end S101: begin if (in) next_state = S1011; else next_state = IDLE; end S1011 : begin next_state = IDLE; end endcase end endmodule
Which I then attempt to run in QuestaSim using the following commands
(The example file above has been saved as "tb.sv")
vlib work vmap work work set UVM_HOME C:/Data/uvm-1.2/ vlog +acc -work work +incdir+$UVM_HOME C:/Data/uvm_example/tb.sv vsim -t fs -vopt -voptargs="+acc +cover" +incdir+$UVM_HOME work.tb
However I am getting a fatal error when the test routine checks for the connected interface:
# UVM_FATAL C:/Data/uvm_example/tb.sv(274) @ 0: uvm_test_top [TEST] Did not get vif
I cannot spot the error. Can anyone see it?
I also am not sure whether QuestaSim will support using UVM like this?
Alex
The problem has been spotted.
Note: there is a typo in some of theuvm_config_db#()::get()/set()lines, where I have mixed up "des_vif" and "des_if" for the handle!
Totally didn't spot it!
- RichardT_altera
I am using Questa Intel FPGA Edition-64 2022.1 Revision: 2022.01
I run using the tb.sv provided, along with the command, and does not see any fatal error.
Richard Tan
- RichardT_altera
The fatal error is generated from the tb.sv itself. You might need to check line 274.
- AlexBeasley
Totally didn't spot it! - RichardT_altera
Great to hear that! With the issue resolved, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
