BHoey
6 years agoUsing SignalTap over SoC Ethernet
I found items from 2015/16 for doing remote system debug on Rocketboards and github (links at the end) by placing a "SLD Hub Controller" off the h2f bus in a SoC device. I see references to a AN693 ...
EBERLAZARE_I_Intel
6 years agoHi,
I deeply apologize for the delay in response,
Yes, the SLD component in Qsys does not appear by default in the new Platform Editor versions(after 19.3),
However, you can still access it using the following command line invocation:
qsys-edit --debug
Once the tool opens, right-click on any entry in the IP Catalog and select
"Show hidden components"
Once you have the IP save in a .ip file, you can continue to parameterize and use it within the design without using the --debug flag.
Hope this helps, let me know if you have further questions.
