sogun3
5 months agoUsing Quartus with softHSM
Hi, I am trying to use quartus to create a signed AES key that is created with softHSM: This command runs fine: $quartus_encrypt --family=agilex7 --operation=MAKE_AES_KEY -a test_aes_key.txt --mod...
Farabi_Altera
5 months agoHello,
quartus_encrypt fully supports HSM-backed keys, including SoftHSM. (QEK creation succeeds)
quartus_pfg is different code path and does not accept HSM-related options (you got Error (21999) : Found unsupported option string: module)
Can you try below:
create AES key without HSM wrapping:
$ quartus_encrypt --family=agilex7 --operation=MAKE_AES_KEY -a test_aes_key.txt aes_key.qek ..
then use the key with: $ quartus_pfg --ccert ..
regards,
Farabi
