EHepl
6 years agoUsing Quartus 19.1 Lite on Windows 10 - Platform Designer failed when executing "Generate HDL". Appears that command "wsl" is missing?
Trying to "Generate HDL". No errors reported while constructing system in platform designer GUI, but when "Generate HDL" button pressed, errors appear. Please see attached "log". Appears to be loo...
RichardT_altera
6 years agoAfter checking, it seems there is an issue starting with the Quartus in window version 19.1 when generating any EMIF IP or Cyclone® V/Arria® V HPS IP in qsys. "FATAL: Cannot generate IP in a Windows evironment!"
Unfortunately the patch is only available for Quartus Standard Edition, I would recommend to use back Quartus 18.1 Lite Edition for now or Quartus19.1 Standard Edition with the patch installed. The Quartus linux version seems to be not impacted. Until then, please wait for the Quartus v20.1 Lite Edition release (probably in Q3/Q4) and hopefully that the issue has been solved.
