13 years agoUsing LPM DIVIDE inside VHDL Block
I am currently trying to implement Color Constancy algorithm for image processing. The algorithm requires at least one division operation (NUMER: 40 bits and DENOM: 40 bits). After scouting relevant posts, it seems that LPM_DIVIDE megafunction suits my requirement. However, I am not entirely sure in implementing the divide function inside my block as well as when to expect the correct output (Note: I am very new to VHDL and FPGAs). Kindly advise on any corrections required. With my code, I obtained these errors using LPM_DIVIDE: ** Error: /home/robocup/Desktop/Old Board Apply Color Constancy/ColorConstancy.vhd(213): Illegal sequential statement. ** Error: /home/robocup/Desktop/Old Board Apply Color Constancy/ColorConstancy.vhd(231): VHDL Compiler exiting Also, it is very likely that 40bits/40bits result might not be obtained within a single clock - which is fine as long as I can implement a checker. Any suggestion on this part? Vincentlibrary ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library lpm;
use lpm.lpm_components.all;
-- This entity is to calculate normaliser at each frame.
entity ColorConstancy is
generic(
DATA_WIDTH : integer := 10;
COORD_WIDTH : integer := 10;
RGB_WIDTH : integer := 40
port
-- Clock signal
CLK : in std_logic;
-- Input signals
R_IN : in unsigned (DATA_WIDTH-1 downto 0);
G_IN : in unsigned (DATA_WIDTH-1 downto 0);
B_IN : in unsigned (DATA_WIDTH-1 downto 0);
DVAL : in std_logic;
FVAL : in std_logic;
-- Output signals
R_DYN : out unsigned (RGB_WIDTH-1 downto 0);
G_DYN : out unsigned (RGB_WIDTH-1 downto 0);
B_DYN : out unsigned (RGB_WIDTH-1 downto 0);
NORM : out unsigned (RGB_WIDTH-1 downto 0)
end entity;
architecture rt1 of ColorConstancy is
component LPM_DIVIDE
generic ( LPM_WIDTHN : natural; -- MUST be greater than 0
LPM_WIDTHD : natural; -- MUST be greater than 0
LPM_NREPRESENTATION : string := "UNSIGNED";
LPM_DREPRESENTATION : string := "UNSIGNED";
LPM_PIPELINE : natural := 0;
LPM_TYPE : string := L_DIVIDE;
LPM_HINT : string := "UNUSED"
port (NUMER : in std_logic_vector(LPM_WIDTHN-1 downto 0);
DENOM : in std_logic_vector(LPM_WIDTHD-1 downto 0);
ACLR : in std_logic := '0';
CLOCK : in std_logic := '0';
CLKEN : in std_logic := '1';
QUOTIENT : out std_logic_vector(LPM_WIDTHN-1 downto 0);
REMAIN : out std_logic_vector(LPM_WIDTHD-1 downto 0)
end component LPM_DIVIDE;
-- Various states
type state_t is (
first_frame,
wait_for_new_frame,
wait_end_of_frame,
calc_norm,
calc_new_RGB,
calc_RGB_dyn
-- Current state
signal state : state_t;
-- RGB sums
signal R_sum, G_sum, B_sum : unsigned (RGB_WIDTH-1 downto 0);
signal R_sum_temp, G_sum_temp, B_sum_temp : unsigned (RGB_WIDTH-1 downto 0);
-- RGB normaliser
signal normaliser : unsigned (RGB_WIDTH-1 downto 0);
-- Colour Constancy variables
signal R_thresh : unsigned (RGB_WIDTH-1 downto 0);
signal G_thresh : unsigned (RGB_WIDTH-1 downto 0);
signal B_thresh : unsigned (RGB_WIDTH-1 downto 0);
-- LPM DIVIDER
signal R_dyn_thresh : std_logic_vector (RGB_WIDTH-1 downto 0);
begin
process (CLK)
BEGIN
if (rising_edge(CLK)) then
if (DVAL = '1' and FVAL = '1') then
-- Next pixel, same frame
R_sum <= ( R_sum + resize(R_IN, RGB_width) );
G_sum <= ( G_sum + resize(G_IN, RGB_width) );
B_sum <= ( B_sum + resize(B_IN, RGB_width) );
end if;
case state is
when first_frame =>
if (FVAL = '1') then
state <= wait_for_new_frame;
end if;
-- Initialise
R_sum <= to_unsigned(0, RGB_width);
G_sum <= to_unsigned(0, RGB_width);
B_sum <= to_unsigned(0, RGB_width);
R_sum_temp <= to_unsigned(0, RGB_width);
G_sum_temp <= to_unsigned(0, RGB_width);
B_sum_temp <= to_unsigned(0, RGB_width);
normaliser <= to_unsigned(1, RGB_width);
-- Orange Thresholding
R_thresh <= to_unsigned(230, RGB_width);
G_thresh <= to_unsigned(128, RGB_width);
B_thresh <= to_unsigned(23, RGB_width);
-- Wait for new frame
when wait_for_new_frame =>
state <= wait_end_of_frame;
end if;
-- Wait until end of frame
when wait_end_of_frame =>
if (FVAL = '0') then
-- End of frame, start normaliser calculation
state <= calc_norm;
-- Save the current RGB sum
R_sum_temp <= R_sum;
G_sum_temp <= G_sum;
B_sum_temp <= B_sum;
-- Reset RGB sum counter for new frame
end if;
-- Calculate Normaliser
when calc_norm =>
state <= calc_new_RGB;
-- TO BE OPTIMISED
-- Approximate normaliser = biggest element + medium element / 2
if (R_sum_temp > G_sum_temp and R_sum_temp > B_sum_temp) then
if (G_sum_temp > B_sum_temp) then
normaliser <= R_sum_temp + (G_sum_temp srl 1);
else
normaliser <= R_sum_temp + (B_sum_temp srl 1);
end if;
elsif (G_sum_temp > R_sum_temp and G_sum_temp > B_sum_temp) then
if (R_sum_temp > B_sum_temp) then
normaliser <= G_sum_temp + (R_sum_temp srl 1);
else
normaliser <= G_sum_temp + (B_sum_temp srl 1);
end if;
else
if(R_sum_temp > G_sum_temp) then
normaliser <= B_sum_temp + (R_sum_temp srl 1);
else
normaliser <= B_sum_temp + (G_sum_temp srl 1);
end if;
end if;
-- Adjust RGB sums to grey world assumption
-- 1) Approximate sqrt(3), by multiplying with 55 (0011 0111).
-- 2) To be divided by 32 at next state.
R_sum_temp <= ((R_sum_temp sll 5) + (R_sum_temp sll 4) + (R_sum_temp sll 2) + (R_sum_temp sll 1) + R_sum_temp);
G_sum_temp <= ((G_sum_temp sll 5) + (G_sum_temp sll 4) + (G_sum_temp sll 2) + (G_sum_temp sll 1) + G_sum_temp);
B_sum_temp <= ((B_sum_temp sll 5) + (B_sum_temp sll 4) + (B_sum_temp sll 2) + (B_sum_temp sll 1) + B_sum_temp);
when calc_new_RGB =>
state <= calc_RGB_dyn;
--Calculate Dynamic RGB and divide by 32
-- R_start = 230 (1110 0110).
R_thresh <= (((R_sum_temp sll 7) + (R_sum_temp sll 6) + (R_sum_temp sll 5) + (R_sum_temp sll 2) + (R_sum_temp sll 1)) srl 5);
-- G_start = 128 (1000 0000).
G_thresh <= ((G_sum_temp sll 7) srl 5);
-- B_start = 23 (0001 0111).
B_thresh <= (((B_sum_temp sll 4) + (B_sum_temp sll 2) + (B_sum_temp sll 1) + B_sum_temp) srl 5);
when calc_RGB_dyn =>
------ DIVISION REQUIRED HERE FOR R_thresh, G_thresh and B_thresh -----
div_component: LPM_DIVIDE
generic map(
LPM_WIDTHN => 40,
LPM_WIDTHD => 40,
LPM_NREPRESENTATION =>"UNSIGNED",
LPM_DREPRESENTATION =>"UNSIGNED",
LPM_PIPELINE => 0,
LPM_TYPE =>L_DIVIDE,
LPM_HINT =>"UNUSED"
port map (
NUMER => std_logic_vector(R_thresh),
DENOM => std_logic_vector(normaliser),
ACLR => '0',
CLOCK => CLK,
CLKEN => '1',
QUOTIENT => R_dyn_thresh,
REMAIN => open
end case;
end if;
end process;
R_DYN <= R_thresh;
G_DYN <= G_thresh;
B_DYN <= B_thresh;
NORM <= normaliser;
end rt1;
