16 years ago
Using both edges of a clock
Hi there,
We have some old design modules from way back and being used in several products. The design is messy and doesn't have any documentation, making it quite time-consuming to rewrite and/or debug them. Sometimes we got hold time violations in the design and it is the most likely because the design uses both edges of clocks.
My questions are:
How does QII implement a design like this? Does QII automatically invert the clock and put both clocks (the one and the inverted one) on global networks? If it doesn't, is there an easy way to constraint the design?
Hua
    There is something odd with that clock.
    In first place, the input pad of the clock has a fanout of 32. This is already odd, because a global external clock has normally a single fanaout, to the clock control block.
    In second place, according to that report it would seem that the clock is routed globally to the source register, but not globally to the destination one. You can get additional routing details with the parameter "-show_routing" on the timing report.
    Check the clock paths with the post-fit technology viewer as well.
    --- Quote Start ---
    --- Quote End ---
    Hi vjAlter,
    You are right. The post-fit technology viewer shows that the clk for the destination register is connected to the output of the IO_IBUf, not the output of the CLKCTRL. Following that clue I found that I actually didn't explicity define the clk_7m as a global clock, only defined it as a clock in timequest. The compiler automatically prompted it as global signal but it looks like the compiler only prompted part of the network (is this possible?). I will set it as a global clock explicity and give it a try.
    Thanks again!
    Hua
    I don't think an explicit global assigment is the solution to the root of the problem. Quartus normally won't promote a clock just to some registers.
    You should investigate what is causing this. Check Quartus compiler warnings, fix all those unconstrained clocks, run the assistant for correct synchronous design, etc.
    --- Quote Start ---
    --- Quote End ---
    Just did a compile with all the clocks set to global explicitly and the timing violation was gone. But it may take a few compilation to find out if this problem is indeed gone.
    Thanks again.
    Another compilation and it's till ok. The fanout of the input pad for the clock is 1. The sending and receiving registers are both clocked from the CLKCTRL output now.
    As I know the main reason of hold violations is that data arrives faster than clock. In FPGAs it is rare due to the built-in delays of the logic blocks and routing resources.
    However, excessive delay on the clock line can cause hold violations. Some synthesis tools may correct this situation, and some might not. I am not sure about Quartus II native syntheser.
