--- Quote Start ---
There is something odd with that clock.
In first place, the input pad of the clock has a fanout of 32. This is already odd, because a global external clock has normally a single fanaout, to the clock control block.
In second place, according to that report it would seem that the clock is routed globally to the source register, but not globally to the destination one. You can get additional routing details with the parameter "-show_routing" on the timing report.
Check the clock paths with the post-fit technology viewer as well.
--- Quote End ---
Hi vjAlter,
You are right. The post-fit technology viewer shows that the clk for the destination register is connected to the output of the IO_IBUf, not the output of the CLKCTRL. Following that clue I found that I actually didn't explicity define the clk_7m as a global clock, only defined it as a clock in timequest. The compiler automatically prompted it as global signal but it looks like the compiler only prompted part of the network (is this possible?). I will set it as a global clock explicity and give it a try.
Thanks again!
Hua
