RAAM1232
1 year agoUsing Active HDL as simulator on quartus prime lite
I am trying to run Active hdl student version simulator using quartus prime lite however after opening running the rtl simulation active hdl opens and shows an error picture is attatched please if anyone has a solution
- ShengN_altera
Have you run using the native link?
Go to Tools -> Options -> EDA Tools Options and set the active hdl path
Go to Assignments -> Settings -> Simulation and setup tool name, testbench file
Full compilation
Go to Tools -> Run Simulation Tool -> RTL Simulation
If use IP, make sure include the .sip file.
Sheng
- ShengN_altera
May I know do you have any further concern or update?
Sheng
