USB Blaster II Problem
For a moment, it worked - I was able to unplug and plug it back in successfully. But now the same problem has returned.
Starting and stopping jtagserver is only a workaround, but I can live with it for now.
Hi lkarp1,
Thank you for the update.
Based on similar reports, this behavior can happen when the USB-Blaster II is plugged in while jtagserver.exe is already running. In that case, the cable may appear as "USB-Blaster variant" and the TCK frequency field is not available. A known workaround is to stop jtagserver.exe first, then plug in the cable, and open Programmer again. [1](https://community.altera.com/discussions/quartus-prime/usb-blasterii-mounts-as-usb-blaster-variant/337405)[2](https://www.intel.com/programmable/technical-pdfs/683039.pdf)
Please also check the following:
1. In Device Manager, confirm the driver is installed from:
<Quartus installation>\drivers\usb-blaster-ii
2. Set the Altera JTAG Server service to Manual, or reinstall the JTAG server from the Quartus version you are using with:
jtagserver --uninstall
jtagserver --install
3. Try using the standalone Quartus Programmer or the latest available programmer package for your flow, so the driver and jtagserver versions match. (https://community.altera.com/discussions/quartus-prime/usb-blasterii-mounts-as-usb-blaster-variant/337405)(https://community.altera.com/discussions/boards-and-dev-kits/instructions-for-driver-installation-usb-blaster-iii-step-1-/89496)
Since the cable works on other machines, this points more to a host-side driver or service issue on this PC rather than a hardware issue with the programmer itself. (https://community.altera.com/discussions/quartus-prime/usb-blasterii-mounts-as-usb-blaster-variant/337405)
If the issue still persists, please share:
- Quartus edition and version
- Windows version
- Output of jtagconfig when the cable shows as "USB-Blaster variant"
Fakhrul
